Sorry for the delay getting back because I really appreciate your answers. Our worst drought in 103 years is finally over and the DSL systems need to deal with water and lightning again.
Are all the batteries the same capacity?
Yes, they are all Costco GC batteries, just a few years difference in age.Do you have two solar systems?
No, just the Renogy panels with the Wanderer charge controller.Why do you want to turn off the Bogart controller? [COLOR=]Not sure what a Bogart controller is. I placed a toggle switch in my converter which lets me turn off the battery charger when dry camping. Plus the charger in the inverter is better than the Trimetics one.Combined with the monitor this is a very good set up.
What controller is on the barn batteries?
WandererIt sounds like you have the RV inside the pole barn and have a separate solar system for the barn.
CorrectIf so, yes you should be able to connect to the RV bank and keep those batteries charged. If the batteries are significantly older - then you may have some issues with the batteries pulling charge from the other bank.
Good, thats what I was thinking. Down the road, I'd like to investigate a docking-like setup that charges and uses the RV batteries in the pole barn grid when home.But if all the batteries are in pretty good shape and you don't have any large loads it should keep them all charged up.
Thats what I'm hopingThanks everyone, this was very helpful.
2014 Chevy 2500 Duramax, short bed, 4WD
2004 Keystone Laredo 27RL
Escapees member
