stove burner
jackbuck
One burner will lite with match but not with spark -other two work fine what do i need to do to fix -thanks ??
jackbuck ,2016 Arctic Fox 29-5-k ,2004 chev 3500 crew with 8100gas,Virginia.One great wife two trailor dogs,9 boys and 2 of the other kind.,all on their own, empty nest. its hard to see the picture when you are inside the frame.
8 REPLIES 8
Boon_Docker
Good to hear that the problem has been rectified.
jackbuck
Thanks to all -lifting the wire off of the metal solved the problem
agesilaus
Also on some burners there are small holes and such that may need to be cleaned out.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
wa8yxm
First make sure ignitor is connected to spark generator. (Wire loose?) and then .. well far as I know you can not adjust them. Had the same problem Tried, Use gas-match or hand held sparker now days.
ScottG
If it will light with a match, it isn't a gas supply issue.
Probably the wire pulled off the electrode or it is shorting through damage to the insulation as suggested above.
Heatshrink will do a clean job of fixing damaged insulation.
pigman1
When that happens, you usually have an igniter wire off or the wire has a slight crack in it and it's shorting to the stove pan. Access the burner area and check the wire and then put something non-conducting between the wire and the stove pan. if it lights then, remove the wire and take it to an electrical supplier for replacement. You'll have to get end terminals and crimp them on. An emergency repair can be made with a few dabs of Liquid Tape (easily found in automotive area of Wal Mart) once you find the cracked insulation area.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
Boon_Docker
jackbuck, check that the wire (igniter) has not come loose or moved away from the burner.
donn0128
Most RV stoves have a gas tube from a central igniter that feeds gas from the burner to the igniter. Lift the lid and look. I would guess the tube has burned or come disonnected.
