โDec-30-2014 05:19 PM
โDec-31-2014 01:50 PM
bka0721 wrote:Good stuff!
Either upgrade your battery bank to meet your needs, or modify your uses by just shifting the uses to when power is coming in and power going out. What are your priorities?
โDec-31-2014 12:22 PM
vtchris wrote:Well, what we want and what we do is often changed with life in a RV. During different seasons, your charging and battery capacity changes. Often times you need to learn to adjust something, that being your battery capacity or use of what battery capacity you do have. Your choice.
But then in the evening when the sun goes down is when I want the most juice.....LED lights, fan for heater, 2 laptops. Plus have enough left over for heat in the morning. I have been told to never let the batteries go below 11.9 so get cautious around 12.5 and just turn everything off and go to bed.
โDec-31-2014 11:25 AM
โDec-31-2014 11:23 AM
โDec-31-2014 09:10 AM
โDec-31-2014 09:03 AM
vtchris wrote:Not if solar is keeping batteries above 12.2 volts.
Thanks guys! For the info and the humor! One more question....when I am plugged into shore power is there any reason to turn my converter on?
โDec-31-2014 08:49 AM
โDec-31-2014 08:24 AM
Yes.
โDec-31-2014 08:18 AM
โDec-31-2014 07:50 AM
โDec-31-2014 06:57 AM
โDec-31-2014 06:41 AM
โDec-31-2014 06:01 AM
โDec-31-2014 05:55 AM
