Subject as read
Cottontop
What happen to the box that showed you have read the subject.
1998 Beaver Patriot (Magnum)
FMCA- Good Sam - CAT (3126)
PT Cruiser AUTO with Remco 4down
11 REPLIES 11
Cottontop
I also stay logged in.
BluegrassBill
I stay logged in also.
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
Gene_Ginny
Cottontop wrote:
Gene & Ginny I wish mine would do that but it doesn't.
Are you logged in? I always use the Woodalls portal and I never log out but if I look at RV.NET portal I am not logged in there and all the posts show as "unread".
I have also noticed that "unread" depends on your last visit not which subject you have actually read. Example: If I leave Woodalls at 10PM on Monday then the next time I visit the only subjects that show "unread" are the subjects that had posts after 10PM on Monday.
It seems the portal looks at the time in your previous session cookie to determine when you were last active. If you clear your cookies then everything will be unread, and you have to log in again. Unlike vBulletin forums that store your "last login" time by username, this one seems to depend on the timestamp in the session cookie.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
BluegrassBill
Used to be when I read a topic the topic that I read would have a dotted line around it. Now it no longer does that, What changed ? The yellow in the circle to the left of the topic stay's yellow after being read.
Cottontop
wa8yxm
Sadly not that I have found till the thread goes to multiple pages.
I do like that feature in some of the well designed forums I read.
But then I go back to the days when you paid for connect time by the minute and at 300 baud so scrolling through a ton of traffic to get to the new posts was..... Not practical... And the programmers knew that.
mgirardo
You only get the option to go to the first unread post if the topic goes beyond 1 page.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Jpatrickc
Is there a way to go to the first unread post instead of having to scroll through all the posts that I have already read?
Patrick Campbell
State College, PA
2011 Carriage Cameo 37KS3
2006 Chevy Silverado extended cab LBZ Dually
Gene_Ginny
Harvard wrote:
If you are logged in the symbol in the left hand column will be coloured if it has NOT been read by the logged in user. Otherwise the symbol has no colour filling.
Subject has new posts
Subject has no new posts
Gene and DW Ginny
Cottontop
Harvard, I am glad that works for you but it does not for me.
Harvard
