Suburban LP Only Waterheater
diftw
A friend of ours is having an issue with his LP only Suburban waterheater. When he tries to ignite it, you can hear it trying to light but it doesn’t. He said he tried to light it manually this weekend-it started to work then shut off almost immediately.
Would anyone have any ideas why it is not lighting. I believe the camper is a new Wildwood X-Lite.
Thanks.
Dave and Anne
2016 Grand Design 337RLS
2015 Ford F350 XLT 6.7l 4x4
Reese Elite 18K Hitch
Rotochocks
Rota Flex by Trail Air Pin Box
Barker 4-wheel 25 gallon tote
Nights Camped in 2009 - 33
2010 - 37
2011 - 31
2012 - 35
2013 - 42
2014 - 45
2015 - 46
2016 - 51
2017 - 43
7 REPLIES 7
RJsfishin
Hot wire 12v to the gas valve,....lite it manually. If it burns correctly,
its a stat or board problem.
You can use it that way till its fixed... (if you need to) but set your timer for 30 minutes !!!!
And I dint tell you that
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Old-Biscuit
Suburban SW6D.....6 gal direct spark ignition
Check out:
DSI---Pg 10
Diagnosis #3 Pg 14
Troubleshooting Guide Pg 18
http://waterheatertimer.org/pdf/Suburban_Water_Heater_Service_Manual.pdf
diftw
enblethen wrote:
Is this a pilot light or a DSI water heater?
DSI could have dirty or restricted burner tube, bad gas valve, or improperly adjusted ignitor flame sensor.
Pilot light version could be bad gas valve or bad thermo-couple.
Thank you-it is a DSI.
Dave and Anne
Rotochocks
2010 - 37
2011 - 31
2012 - 35
2013 - 42
2014 - 45
2015 - 46
2016 - 51
2017 - 43
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
diftw
SoundGuy-yes that is what he will do if it isn’t something easy to fix on his own.
2oldman-plugged into power and everything else electrical seems to be working well.
Dave and Anne
Rotochocks
2010 - 37
2011 - 31
2012 - 35
2013 - 42
2014 - 45
2015 - 46
2016 - 51
2017 - 43
2oldman
Battery
SoundGuy
Could be any one of a number of issues but since this trailer is new & under warranty wouldn't the obvious solution be to have his dealer address the problem?
2012 Silverado 1500 Crew Cab
