Suburban Water Heater Rusted Out
CabinetmakerII
My wife and I bought our Fiver new in 2011 (2012 Model Year)and went Full Time in 2014. I have been very diligent with the maintenance of all the mechanical systems. Since new, I have drained and flushed the water heater bi-monthly and although it was still in pretty good shape, I replaced the anode 3 times. In spite of my efforts, the water heater started leaking. Having purchased an extended warranty when we bought the coach, I recruited a local/reputable RV repair facility to assist with the repairs and deal with the insurance company. The repairs were facilitated with no other issues.
Now to the point... With the old water heart removed, we took off the foam blanket which exposed the rusted tank. The technician said it had rusted from the inside out and it was fortunate that we noticed the leak when we did as it could have lead to a catastrophic failure and flooded our coach.
With all of the preventative maintenance and effort to keep things operational, what more could I have done? Did I miss something in my procedures? I may have been absent that day!
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2018 Polairs 1000 XP Side by Side
8 REPLIES 8
CabinetmakerII
All: Thanks for the input. ScottG, Went with another suburban as the insurance company was paying for "Like Type and Kind"
Path1, I don't recall what the anode rod was made of. I do recall noticing it was a different material than my previous coach. Also, I would estimate the anodes I replaced were less than 30% spent.
Old Biscuit/DownThwAvenue, In retrospect, I am inclined to agree with you. Would have been interesting to "Cut Away" a section and get a look at the inside of the tank.
Perhaps we will be in a new coach before this WH goes belly up...
Cabinetmaker
2021 DRV 39 DBRS3
CJW8
My glass coating started flaking off. Every time I drained it I'd get bits of glass. Trading RV in was the fix.
2003 Forest River Sierra M-37SP Toy Hauler- Traded in
2015 Keystone Raptor 332TS 5th wheel toy Hauler (sold)
2004 Winnebago Vectra. 2011 Jeep Grand Cherokee toad
DownTheAvenue
Old-Biscuit wrote:
Removed foam insulation and exposed the rusty tank........tech stated it had rusted form inside-out :H
IF that was true it would have been leaking water all over for a long time.
I bet inside of tank was not as rusty and that you had a minor leak at a fitting which made outside of steel tank wet which then rusted (surface rust)
I'm calling BS on that techs conclusion....just not buying it.
X2
Lynnmor
Of course it rusted from the inside, that's where the water is. Sounds like you did the best you could, life of a water heater is much about luck.
Old-Biscuit
path1
Your anode replacement was magnesium or aluminum? Many places in US the water is very destructive. I replace my anode when 50 percent or more is gone (worn out), with magnesium anode. Aluminum anode is longer lasting, but that also means more wear inside tank IMO. In Yuma, AZ on well water, I replaced every three months. I always get out old stuff with a tank cleaner nozzle. Other than above, maybe you got one that was broke from the beginning? Good thing you got it when you did.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
ScottG
With a healthy anode, it should never rust - even with a defect int he glass liner.
In some area's the water is so hard it will deplete an anode very quickly. It must have worn down enough at some point to allow the damage.
Did you replace it with an Atwood WH? Their aluminum tanks are better suited for that kind of situation.
newman_fulltime
at some point the glass liner got cracked
