suggestions for screen door with dog
huskyfan68
so the doggie stuck his head thru the screen door- I know they make several other types designed to be stronger for pets- Is there a material I can purchase from hardware store- cut to size and screw in that will do the same thing? Looking for suggestions- Dog is 80lbs so would need to be strong
20 REPLIES 20
BFL13
The screen door pops open easily, so with the plexiglass over the bottom half of the door (so you can still see out of it) also put a sliding bolt inside just below the opening where you get at the main door handle.
From outside you can reach in and undo the sliding bolt. But be careful not to close the main door while that bolt is across or now you can't get in! ( You can but you have to overcome the way the door and screen door hold together)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
opnspaces
Navigator
Navigator
Lowes and Home Depot sell pet resistant screening, it's pretty stout stuff. You cold also try a plexiglass sheet and small self tapping screws on the bottom of the screen door. The Plexiglass can probably be the the thinnest and cheapest they sell at the same home improvement stores above.
MEXICOWANDERER
Screen strips if access is desired. The strips overlap each other.
Grit_dog
Nomad III
Nomad III
Iโ€™ll go out on a limb and say that there isnโ€™t a RV screen door that is made that will withstand even a half hearted attempt by an 80lb dog to go through it.
If youโ€™re concerned about the dog getting out, the storm door will need to be closed.
If youโ€™re worried about the door, reinforcing the screen area will just destroy the door of the dog pushes on it.
And if itโ€™s a Husky, youโ€™re quite likely concerned about the first thing.
Itinerant1
Get a piece of plexiglass. Easily cut to size and screw into door.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,500+ partial cycles.
Pangaea_Ron
Look for expanded metal sheets at hardware stores.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
