Tankless water heater
MP_soldier
Why does the Girard heater have a bypass valve? No matter what, you have to run anti freeze or air through it, so when would you ever need to bypass?
2000 Volvo 770
10 speed Eaton autoshift transmission
Cummins N14
2016 XLR Thunderbolt 420amp Toyhauler
Featuring side and rear deck AND onboard Onan Genny
6 REPLIES 6
MP_soldier
wa8yxm wrote:
Dick_B wrote:
After giving it three seconds thought might one want to bypass the heater to work on it or replace it while still living in the RV?
I've never looked at it but is there a drain? And I really like Dick's answer.
Many commercial installs have bypass valves even though they are designed to NEVER be shut off,, For just that reason.
Nope, no drain. It's tankless.
2000 Volvo 770
Cummins N14
dougrainer
1. They may just have the bypass system despite what model water heater
2. Girards do not have a drain
3. Yes, you have to blow them out and add antifreeze to winterize, but, maybe you do want to use the water system and not have to worry about the water heater after winterizing. Easier to then drain and winterize without blowing out the Water heater again and adding the antifreeze. Doug
wa8yxm
kedanie
Or perhaps using the RV water system in freezing conditions and no hot water is desired?
Keith
Keith and Gloria
2013 Tiffin Phaeton 36GH
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Vietnam Veteran
Old-Biscuit
Ding, Ding, Ding......
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
