โJun-02-2016 11:12 PM
โJun-06-2016 03:18 PM
โJun-06-2016 10:59 AM
โJun-06-2016 10:31 AM
โJun-04-2016 06:05 PM
โJun-04-2016 05:33 PM
....... I have a beer budget with champagne tastes. I need my batteries to last a long long time.
โJun-04-2016 05:09 PM
westend wrote:
Hey Don,
I'm rather a neophyte with VRLA construction but I would think the recombinant gas mechanism would reduce the need for a lot of gassing, irrespective of SG. I might be totally wrong about that?
The Genesis EP AGM's I'm using describe a "reconditioning" process should the batteries lose capacity. IIRC, the voltage is set at 16V for a period of time and there is no admonition about temperature. That's not a real healthy diet IMO. as boiling out any electrolyte would be bad AFAIK.
FWIW, my 6 V bank has the temp compensation connected from the solar controller and that pair is fairing very well. I just recently added water to the cells after a year of nearly constant charging. My controller is set to go into 14.6 bulk for a short period and then floats for the rest of the day if voltages stay above 13.5 V. The SG remains at a baseline 1.30 while in storage.
โJun-04-2016 04:50 PM
โJun-04-2016 03:13 PM
โJun-04-2016 01:06 PM
โJun-04-2016 12:17 PM
pianotuna wrote:Good question and could get quite theoretical/technical in answering. One unknown is: Are both of the specific gravity densities you listed at the full SOC measured density?
Does anyone know if a higher specific gravity increases temperature for charging rates?
Example:
1.275 vs 1.30 can temperature be higher for the 2nd number when charging?
โJun-04-2016 10:52 AM
MEXICOWANDERER wrote:I particularly like the title, "TECHNICAL MANUAL For Lifeline Batteries". It doesn't say "TECHNICAL MANUAL For AGM Batteries".
Naio, download and read this PDF manual. You can trust the information.
https://www.tayna.co.uk/docs/datasheets/lifeline/lifeline-manual.pdf
โJun-04-2016 12:28 AM
โJun-04-2016 12:25 AM
โJun-04-2016 12:10 AM
