โMay-27-2010 02:06 AM
โJul-05-2011 11:09 AM
โJul-05-2011 09:17 AM
#40Fan wrote:
I guess it was pretty easy to wire up?
โJul-05-2011 06:15 AM
โJul-04-2011 08:32 PM
Oletop wrote:
I installed the maintenance minder hour meter by Briggs and Stratton. It works well and very easy to hook up. It is also yellow so it matches pretty well. The pics shouldn't be more than 4 or 5 pages back.
I connected my Briggs and Stratton MainteanceMinder hourmeter. I tested it out and it works. I registers in 1/10 hour which is 6 minutes. It is yellow and comes with 3M sticky pad on the back for easy mounting. I took the side panel off which is on the oil dipstick and spark plug side. I also took the top off and the grey/silver snap on corner piece. I pulled the top rubber grommet out of the corner and used a small drill bit to make a notch in it for my wire to sit. I ran my wire and pushed therubber grommet back into place and replaced the corner piece. I then placed a lock washer under the black handle where the wire comes out just so that it would not smash and possibly short the meter. No visible holes were made anywhere for the wires and everything works and looks nice in my opinion. Now it easy to keep track of the hours run for maintenance. It also registers the Max RPM. I'll take pics and post later.
David J.
โJul-04-2011 08:11 PM
โJul-04-2011 07:57 PM
โJul-04-2011 07:54 PM
#40Fan wrote:
Sorry, guys, but 81 pages and I don't see a "search this post" option.... so..
Anyone install an hour meter on one of these?
Pertaining to the above post, anyone dug into the carb to see what the jet looks like? Already at 4500 ft. and will be climbing when I camp. Would hate to run into any problems. Changing jets would be a cake walk.
โJul-04-2011 07:37 PM
โJul-04-2011 06:21 PM
โJul-04-2011 01:34 PM
โJul-04-2011 01:36 AM
โJul-03-2011 10:08 PM
JConatser wrote:
My local Sam's Club is selling them for $489. I wouldn't pay more than that.
โJul-03-2011 07:35 PM
Oletop wrote:
Ran a test yesterday. I was running a 6500 BTU window A/C. I let it run for about 5 minutes, then attempted to start another 6500 BTU A/C. No Go. What I did find interesting and different from Proffessors tests is that my Breaker tripped. I knew that it was not going to work but I had to do it. I tried to start a 13500 btu RV A/C and it was a no go as well. It also tripped the breaker. The manufacture date on my Gen is 7/2010. I am happy with my CPE 2000 and will add another to my arsenal.
โJul-03-2011 04:39 PM
โJul-02-2011 04:01 AM
