โDec-27-2021 08:37 AM
โDec-30-2021 05:35 PM
NRALIFR wrote:
Did you know that -40C and -40F are equal, identical, and equivalent???
And just as cold as each other!?!?
I didnโt. Till I looked it up.
โDec-30-2021 04:42 PM
โDec-30-2021 04:31 PM
StirCrazy wrote:
the ops case is extream, but not uncomon. I have taken a camper across country in -35 and it isnt fun.
โDec-30-2021 09:23 AM
โDec-30-2021 09:07 AM
โDec-30-2021 08:44 AM
โDec-30-2021 07:50 AM
โDec-30-2021 04:44 AM
pianotuna wrote:yes they are much better than AGM, agm is the worst in my opinion and anything is better than that. they just fit a nich market of anti spill
SiO2 are much better than regular AGM, which are better than flooded. They have little or none of the monkey business needed for Li chemistries.
pianotuna wrote:
There is only one Li chemistry (Lithium Titinate) that would meet my weather needs (not wishes), but it is $1800 per 100 amp-hours, and many would be required because the recommended discharge rate is rather low. SiO2 can do 4C continuously.
pianotuna wrote:well thats not entirly true, they use Li batteries in skidoos, and quads and they seam to work fine in the cold. but thats another issue and not as relivent in this situation. yes that is the one downfall you need to be above 0 for the battery to charge but it is easily acheavible
Li are not well suited to cold except for the aforementioned above.
pianotuna wrote:
I fail to see how I could warm li batteries up to where they could be charged without using shore power, or a generator. Physical space will only allow 7 group 29 jars. Li are not that much smaller in dimension, and for MAXIMUM cycle life really only have 50% usable (40% to 90%).
pianotuna wrote:
Li do not love to be float charged. That means adding complications to the solar charging system for storage. SiO2 don't mind float at all.
โDec-29-2021 06:06 PM
โDec-29-2021 05:52 PM
pianotuna wrote:
Hi Folks,
This is why Li batteries are not a good fit for me.
https://weather.gc.ca/city/pages/sk-32_metric_e.html
-40 on Wednesday night.
โDec-29-2021 10:21 AM
โDec-29-2021 09:39 AM
โDec-29-2021 06:20 AM
LittleBill wrote:StirCrazy wrote:valhalla360 wrote:3 tons wrote:SDcampowneroperator wrote:LittleBill wrote:Wont the heating option then use battery power?
this has been solved. they now sell bms's with heating options. When I make the switch they will be used in 0f unprotected temps.
No, the heating option is powered by the batteryโs charging source.
3 tons
If there is a constant charging source, no need to mess about with a large battery bank...which is the primary reason to install lithium.
Of course, if there is a charging source, a small heating blanket negates the temperature issue of cold.
may not be shore power they are using to preheat the batteries, it might be solar. once the batteries are preheated there is no need to keep them warm as the furnace will be warming the space there in, if they are set up properly. all the BMS does is redirect the power it recives to heating pads or what not instead of the batteries untill the internal temp of the batteries is high enough for them to safely accept a charge. but people keep forgetting that you can discharge LFP batteries in most cases to -20C so in reality you could start the furnace and warm up the rv. If you have the batteries inside the heated space, this inturn would also warm up the batteries, and all you need to do is install a disconect on your solar panels that you can leave off untill they are warm. theres always ways around cold if your willing to look for them.
Steve
Pretty much, the bms's have a configuration for min temp for charge, pretty simple. the battery doesn't charge until the temperature goes up to a set point , at which point it stops heating and redirects the charge into the battery's themselves.
Also don't need a solar disconnect since its in front of the bms, bms will just use the solar to keep the battery's warm, no different than any other charge source.
LittleBill wrote:
OP's case is extreme, and shouldn't be considered for a normal use case. Still I would be confident I could keep them warm at -40, with an insulated box, and the heating pads I have looked at... Will it extend charge times? Yes... how much I don't know. But at -40, my generator is prolly running a lot. also how are you dealing with water and tanks? seems like that's a bigger issue to handle power wise, then the battery component.
I have camped so far to about 20F, and its prolly the coldest I'm going. I have single pain windows, and were easily the coldest component of the rv.
let the op buy his batteries. hope they work, for everyone else a heated bms, pretty much allows the lith's to sit outside unprotected. Which is where mine are going.
remember charge/vs use are different values. Most people are not camping below the use case scenario. and in my case. the bank will be so large. I prolly won't need to charge the entire time I am there.
โDec-28-2021 06:03 PM
pianotuna wrote:
My own personal belief is that no battery bank should be in the living quarters, unless there is a sealed box vented to outdoors, but others may do as they wish. After all, it is a free country.
โDec-28-2021 10:03 AM
