Tilt bed controller
westnavy
My tilt bed controller is only raising bed about 6 inches then it seems that itโ€™s amping out ( no further movement up/down), until I reset the configuration button. I contacted mfg and theyโ€™ve been little help. Do these controllers fail in this manner? How much are they to replace?
1 REPLY 1
RandyandMarla
The controllers do go bad every so often. I just replaced my Lippert controller with a new one for $109. Also check your wiring beneath the bed. Sometimes a wire to the motor or switch breaks or come loose causing the problem. If all the wiring looks good, it's probably your controller.
Randy and Marla
2013 Itasca Ellipse 43AD
2014 Jeep Rubicon
