โJan-12-2015 10:41 AM
โJan-12-2015 09:35 PM
โJan-12-2015 07:59 PM
โJan-12-2015 07:46 PM
2oldman wrote:
What is the max pressure rating printed on the tire?
โJan-12-2015 07:28 PM
2oldman wrote:My thought was that if one axle was not square with the frame, and it's a double axle unit, the tires will not be running straight and true. Kind of like if your steering tires were toed in or out too much. Dunno for sure, just seems possible. But I've been wrong before.
I don't get how any sort of axle alignment would result in the kind of wear the OP mentions.
โJan-12-2015 06:03 PM
smkettner wrote:
Here is one of mine with an internal belt shifted or broken. Initially I though the alignment was out.
Actually the alignment was out a bit but did not cause the wear issue.
โJan-12-2015 04:51 PM
โJan-12-2015 04:47 PM
โJan-12-2015 04:46 PM
โJan-12-2015 03:18 PM
Lynnmor wrote:owenssailor wrote:
The tires on my trailer are showing heavy wear on the outside of the tires. This is worst on the right hand side.
Does this indicate bent axles?
Yes
โJan-12-2015 01:47 PM
โJan-12-2015 11:36 AM
โJan-12-2015 11:31 AM
โJan-12-2015 11:14 AM
โJan-12-2015 10:59 AM
