โMay-14-2015 08:33 AM
โMay-14-2015 04:45 PM
lanerd wrote:
I wired mine directly to the battery....is yours? Sounds like it isn't.
Ron
โMay-14-2015 03:49 PM
โMay-14-2015 10:17 AM
โMay-14-2015 09:22 AM
Jack_Diane_Freedom wrote:
My electric tongue jacks have all had an in line fuze in the line going to the battery. Also how is the charge on the batt?
โMay-14-2015 09:07 AM
โMay-14-2015 09:03 AM
CantCampEnuf wrote:ScottG wrote:
It should be wired directly to the battery. Sounds like it is wired to the converter and has a battery disconnect switch between the conv and batt. Or the battery is not in the circuit for some reason - check its wiring.
If you have a disconnect switch, make sure it's on.
I will look for that. I would think if the disconnect switch was engaged, that nothing would work? Thanks for response.
โMay-14-2015 08:38 AM
โMay-14-2015 08:35 AM
