โNov-12-2014 09:28 PM
โNov-13-2014 09:58 AM
MaestroPNW wrote:HMS Beagle wrote:
The correct way to wire them is to run cables between the terminals of the two banks, then take the positive power bus cable to one bank, and the negative cable to the other. Since the current from either (and both) banks goes through these wires, any voltage drop due to them is seen by both battery banks and they will charge and discharge at the same rate (or at least, at rates not influenced by the wiring).
This makes sense, but likely not going to happen in my setup - the second bank will be plugged in through an Anderson connector and be on the outside of the camper. Modifying the wiring in the way that it would hook up to the "remote" bank and be able to unplug it is probably possible but complicated.
โNov-13-2014 09:38 AM
โNov-13-2014 09:15 AM
โNov-13-2014 09:11 AM
โNov-13-2014 08:53 AM
โNov-13-2014 07:58 AM
โNov-13-2014 07:55 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โNov-13-2014 06:45 AM
โNov-13-2014 05:28 AM
โNov-13-2014 05:26 AM
โNov-13-2014 05:24 AM
โNov-13-2014 04:07 AM
โNov-13-2014 04:05 AM
โNov-13-2014 03:58 AM
โNov-12-2014 10:17 PM
