Urgent! Propane Alarm sounding
Fiftybucks
Had propane turned on for days.. no issues..
Wife just now cleaning the interior with Pinesol and vacuum, and Propane Alarm is going off. Can the vapors from cleaners set it off or only propane?
'03 27' Keystone Outback w Dodge 2500 Cummins
17 REPLIES 17
wa8yxm
Google, or in this case Yahoo, is your friend:
Search term: pinesol formulation
Found it contains two forms of Alcohol
Alcohol vapors are explosive and since the proper name of the Propane Detector is "Explosive Gas Detector" yes they will set it off.
how explosive are there... Trust me you do not want to know.. I do, but it was pure wood alcohol, used to fuel a space heater, that blew up in my fact, not the diluted formulation Pinesol uses.
(Thank heavens there was a handy snow bank to roll around in or the burns would have been much, much, worse).
But the bottom line is yes,, Pinsol acn indeed set it off.
SCVJeff
(dup)
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
SCVJeff
riven1950 wrote:
Add raid bug spray to the list
and the neighbors ripe trash in the summer...
Jeff - WA6EQU
riven1950
Boon_Docker
I think you will have a tough time finding a battery operated propane alarm. You can buy a hard wired one from Camping World for a little over $50.
traindriver
My alarm says it is worn out after 5 yrs. If I bought another like it to replace it, it would cost $130.00. I can buy a battery propane and co2 alarm for a lot less money. My question? Would you replace yours with a battery model or with the wired in model? My house alarms are battery and they work just fine.
RJsfishin
Mandalay Parr wrote:
I fixed mine. I stopped cleaning!
I fixed mine, I stopped detecting !
Rich
Johno02
Propane alarms tend to get a bit oversensitive with age. Might need to be replaced.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
joebedford
Nomad II
Nomad II
Don't do this:
- light a match to see if it really is propane
3oaks
I like your fix. :B
Mandalay_Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Fiftybucks
Aired Out, reset sensor... seems OK... has not re sounded !!! thanks... Wife is much less concerned now. We will watch during cleaning as to what agents are present
dewey02
Short answer is Yes. Ours goes off everytime I winterize and pour RV antifreeze into the P traps. Has done this for 3 years. Just air it out and it'll go back to acting normal.
Walaby
bdpreece wrote:
Listed below are some common items that can set off propane detectors
* Hair Spray
* Febreze
* Some Cooking Sprays
* Some spray on sunscreens
* Dog and Human Farts (if this happens you should always blame it on the dog) ๐Ÿ™‚
* Some carpet cleaning chemicals
I am sure that there are even more common chemicals that can set a propane detector off.
Add smelly feet/socks to your list.
Grandson put his feet next to the detector and within a few secs.. set it off.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
