Water Fill Hose Replacement Help
tweedjefferson
Hi All,
I am attempting to replace the water fill flex hose on my '96 Alpenlite 29 (rear kitchen model). Seems like it should be a simple job, but I have a concern before I move on with it...
The existing hose seems to be pinched under some sort of a box or panel. I could cut it and force it out, but am concerned that I wont be able to get the new hose between the service compartment and the water tank inlet. Theres about a foot of hose that I cant seem to access. Does anyone know if there is an additional access point somewhere between where the hose disappears behind the breaker box and where it reappears under the trailer? Any tips for completing this would be much appreciated! Thanks!
***Link Removed***
2 REPLIES 2
chainegang
If the only portion of he fill hose that cannot be seen is not visible for the one foot distance that you described, then I would, if encountering the same problem, disconnect both ends of the hose, secure a line to one end of the hose VERY SECURELY so that it will not come loose when pulling. Pull the hose thru it's path to the other end. Then, secure the line to the replacement hose and pull it back thru the vacated trail of the old hose.
tweedjefferson
The forum deleted the link to my photos on Facebook, so hopefully this Google drive link works!
https://drive.google.com/file/d/1z2N27FiipNBfgoLOme3pMIjby-dnS-Og/view?usp=drivesdk
https://drive.google.com/file/d/1oJk2VIlYPv500J52L5sOsC-v__rVpJp4/view?usp=drivesdk
