Water heater anode rod
drsteve
My two year old Coachmen has a Suburban water heater. How long can I expect the anode rod to last? This is what the current rod looks like:
When I replace it, should I get a magnesium rod, or an aluminum one?
Thanks in advance!
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
18 REPLIES 18
Cummins12V98
Must be some good water along the West Coast! This anode was installed 10/16. I checked it 10/17 and re installed. I checked it yesterday and flushed out the tank with NOTHING coming out. I added liquid teflon to the threads and re installed. Will check again 10/19.
Picture posting does not seem to be working right now.
UPDATE
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dave_H_M
I would start with the 3/8 impact at a low setting. Rattle a bit and then inch up the pressure. Use the big gun as a last resort.
I have a cheap tap that I bought off ebay to chase those threads - just enough to get the crud out of the threads. And I always use Teflon tape on the install.
MFL
Nomad II
Nomad II
Yes, when anode/heater threads are rusted, or corroded, WH can be damaged by use of impact, or cheater bar. If you do get it out, the use of teflon tape will make next removal much easier. Be sure to clean up the threads before reinstalling.
Jerry
Lynnmor
HadEnough wrote:
Any tips on getting corroded rods out of water heaters?
I can't seem to turn mine at all.
An impact wrench will get it out, but there is the possibility of damage.
HadEnough
Lynnmor
SidecarFlip wrote:
I miss the Atwood HWH I ad in my old camper. No anode rod needed. The tank was glass lined.
I understand that Atwood has an aluminum tank and Suburban has a glass lined steel tank. The anode rod is to protect the glass to steel transition at connections.
Old-Biscuit
SidecarFlip wrote:
Don't substitute an aluminum rod for the magnesium OEM rod. Your Suburban water heater tank could get a hole in it if you do.
You have another season left on your rod. I'd get a spare just in case and don't forget to flush out your tank before reinstalling your old rod, the white stuff is sitting in the bottom of your hot water tank and needs flushed out.
Suburban supplies BOTH
Magnesium is OEM rod cause it provides the most protection BUT can react with microbes in water supply and give off a sulfur smell
Aluminum is OPTIONAL rod. Doesn't provide same level of protection as magnesium but is a good option when magnesium creates issues
Pros/cons for either
ktmrfs
how long depends a great deal on the water you use. For us and many of the places we go, the anode rod will last 5 years or more. Anode rod in our S&B lasts 15-20 years, as long as the water heater. Now my folks and brother in midwest replace S&B anode rod every few years and have yet to get 10 years out of a S&B water heater.
2011 Keystone Outback 295RE
mike-s
2 years old, you've got another 5+ years to go with the water you've been using. Less if you run into some bad stuff.
As long as there's some sacrificial metal left at the end of the season, all is good. Looks like you've got at least 80-90% left.
drsteve
Same here.
I gave this one a flush when I was winterizing and was surprised with the flakes and sediment that came out, which I assume is the remains of the rod. I hope none of it decides to make its way to the plumbing fixtures...
SidecarFlip
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
SidecarFlip
MFL
Nomad II
Nomad II
Yes, OEM is magnesium. The mag rods have a little dimple in the center of the head (threaded end).
Jerry
drsteve
MFL wrote:
Magnesium is the recommended choice, and should last for a year, or more, depending on water quality. If really bad water, and going through the mag rods quickly, then the aluminum rod is a better choice, and will last longer. The aluminum rod, does not give as much protection as the magnesium one.
If your current rod is mag, and looks that good after 2 years, you are doing very well, and likely using good water.
Jerry
That's the OEM rod, so I assume it's magnesium. I fill at home with soft water. I have heard that the aluminum rods last longer, didn't know about the lower level of protection. I'll stick with mag for a replacement.
Thanks, guys!
