Noticed the other day that my Suburban 12 gal water heater was not heating on electric. Gas works fine. Replaced the element and it worked for about 10 min then quit. Any suggestions? Really don't want to call a repair guy if I don't have too.
TV: 2012 F250 CC SB SRW 6.7L Diesel w/air lift suspension CHU: 2012 Keystone Montana 3750FL Hitch: B&W Turnover Ball w/ Companion 3500 Family: Me, HH6, a Boston Terrier, a Shiba Inu
Under the cover above gas valve----Left Side 120VAC black wires High temp is top one.manual reset (trips at 180*F) Normal temp is bottom one (Opens at 130*F)
Interesting that it would work for 10 minutes on the new element and then stop again. How did the old element that you removed look? I would start by checking for continuity with a meter on the old element to see if it’s good or bad
1999 R-Vision Trail Light B17 hybrid 2006 Explorer Eddie Bauer 2002 Xterra rollin’ on 33’s 1993 Chevy Z24 Convertible Lives in garage 71,000 miles
Turn off the power and check all connections. A $10 voltmeter (used with safety kowledge) can establish voltage at the element wires. And a clampon ammeter can determine amps. It could also be other components that failed.
2009 Holiday Rambler 42' Scepter with ISL 400 Cummins 750 Watts Solar Morningstar MPPT 60 Controller 2014 Grand Cherokee Overland
