Weird 12 volt problem ~ Solved!!!
_DJ_1
I wanted to relocate the 12v receptacle to a more convenient place for my Engel. Instead of moving the old one and leaving a hole I went to O Reillys Auto Parts and bought the same exact one that I have been using.
I mounted it about 15" apart from the other one. It won't run the Engel. It will run my inverter and my thermoelectric cooler but not the Engel!!! The original still runs the Engel just fine!!
:h:h:h
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
25 REPLIES 25
DougE
On these 12v fridges I've seen some chatter about needing to cut the factory plug and replace with one from Radio Shack.
Currently Between RVs
time2roll
Use Anderson power poles and pull #8 wire ๐Ÿ˜‰
Those cigar plugs are junk ๐Ÿ˜ž
Darryl_Rita
12 volt plugs aren't standardized. 2 different variations, at least. They don't interchange. Look down inside them, betting they're different.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
HiTech
First hit on google is a company the makes AC/DC fridges and freezers.
Jim
jhilley
I am also wondering what an Engel is. It may be that the socket is just slightly different and the center positive connector on the plug doesn't reach the contact in the socket.
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
renoman69
.....and what the heck is an "Engel"?
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
_DJ_1
It is the exact same receptacle with the same length and gauge wire and wired directly to the battery the same as the original.
Not only will the original run the Engel but I can put a dual receptacle in it and run my tv through an inverter at the same time.
I just think that is weird.
3_tons
The AWG wire gauge on the new one 'may' too small to carry the current. Thus, wire could overheat.
Reddog1
Moved to the Tech Issues Forum.
Wayne
Moderator
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
mkirsch
Nomad II
Nomad II
Help people out here...
"Won't run" how? What happens when you plug it in and turn it on? Does it pop fuses, or stand up and sing the Star Spangled Banner, or what?
How did you wire it? Did you wire it from the existing plug, or run a separate circuit? What gauge wire?
What does the voltage read in the new plug? In the old plug?
You've got one of three problems most likely:
1. Bad connection.
2. Inadequate gauge wire.
2a. Too long a run.
YC_1
Could be you reversed the polarity and some devices are protected. Some just won't work. Or, your wires are not carrying the current load and the voltage is dropping.
Grab a voltmeter and touch the outside edges on each of the sockets. If you see voltage the new one is reversed. If it is a low voltage issue you need to measure the voltage right on the back side of the socket while under load.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
