โOct-08-2014 05:11 AM
โOct-10-2014 08:31 PM
โOct-09-2014 04:02 AM
mdamerell wrote:
With your slide in, look for light under the slide from the inside. I lost a piece of seal off the bottom of my slide and it caused floor damage. The shop found the problem by laying on the floor and looking between the slide and the floor. It was letting road spray into the camper.
โOct-08-2014 06:16 PM
โOct-08-2014 04:45 PM
YakFishMo wrote:
Thanks Ken! What did I do wrong? ๐ฎ
โOct-08-2014 03:50 PM
Old-Biscuit wrote:
Slide rides up and over floor when retracted.
Bottom edge of slide out needs to 'seal' against frame of trailer when retracted.
Tires throw water UP when driving in rain. Rain gets in thru bottom edge of slide out if seal is missing/out of position/damaged
Open slide out.crawl underneath and inspect seal/sealing area.
Have someone close slide out while underneath and check how it seals up.
โOct-08-2014 01:43 PM
โOct-08-2014 07:23 AM
โOct-08-2014 06:00 AM
โOct-08-2014 05:56 AM
โOct-08-2014 05:49 AM
โOct-08-2014 05:39 AM
