What is this stuff?
BurbMan
The fridge drain line was old and brittle and broke off so that it was too short to exit outside. I changed the drain line with a new one and in the process found this stuff inside the old one:
Here's what it looks like dumped out on the driveway:
The line was completely full of this stuff, not hard packed in, but more than just a little bit. Any idea what this is?
9 REPLIES 9
dougrainer
udidwht wrote:
I have a newer Dometic RM 8501 and it drains into a small drip cup/tray.
That is because the design of the outside doors. Doug
udidwht
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
Flight System Generator man 360 (PM me)
dougrainer
Dometics are NOT supposed to drain to the back of the refer. They are either installed poking out the lower door holes or secured to the outer lip just behind the access door to drain down the side of the RV. Also, the original drain hose is about 3 foot long with more than enough to loop and then install on the correct exit. If yours was shorter it was because the installers cut off the excess as they did not know the correct install as I mentioned. Norcolds drain into a cup mounted beside the LP burner flue to evaporate any liquid and also the Norcolds have a check valve on the end.
Skibane
^ Yeh, they usually just drain inside the back of the fridge.
Typically, there's not more than a few drops of water produced - if any.
wildtoad
On my 2016 Newmar Bay Star Sport the refer drain line has one of the plugs noted above. It is however siliconed to the cabinet floor inside the cover, not through the grill.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
BurbMan
Sorry I wasn't clear...the original line broke from brittleness and was TOO SHORT to exit through the vent baffle and so was dripping inside the fridge compartment. The end plug was long gone along with the broken end. I replaced the line and added the plug you linked to. Although it's hard to digest the price of that little thing, no bigger than a dime.
My guess was also some kind of insect detritus, I just had never seen anything like and wondered if anybody had. Thankfully fridge is working great, although it hasn't been too hot outside.
dougrainer
From the color, I would say Dometic refer. I think it is some type of insect debris/nest. Also, the original line was NOT too long. The reason it was that length is, it is supposed to be installed with a loop to prevent air migration back up. I will bet in 43 years as a Tech, I have seen maybe 4 or 5 installed correctly in thousands of refers I have worked on. Also, the end of that original tube should have a plug in the end with small holes to prevent insect migration. Holes just large enough to allow water drip out. Also, when you use the drain line you stick it one of the outside lower access door vent holes to allow the water to drain to the outside. Doug
This link shows that plug
https://getrvparts.com/dometic-2932115013-rv-refrigerator-drain-hose-tube-plug-cap/
fj12ryder
Something to let the water through, but keep the bugs out? Rather than a screen on the end?
Howard and Peggy
"Don't Panic"
bgum
Cellulose?
