What System panel do i have?
Rycher
I cant find any info on this thing. anyone seen this before and know the manufacturer?
7 REPLIES 7
Rycher
just fyi for all.. i was able to pull it out far enough to see its a geckotech model ecp. very similar to the KIB's on the market..
mobeewan
Might be able to take the screws out and pull it out far enough to see if there is amfg and moder number. Worse case might need a flashlight and or mirror.
Dusty_R
3 tons wrote:
Dusty R wrote:
Not what you are asking, but check out "Sea Level" tank sensors. A much better system given levels in %. And not very hard to install.
Actually, โ€˜SeeLevelโ€™ by Garnet.
Good catch, thanks.
3_tons
Dusty_R
Dutch_12078
KIB has made panels similar to that one for many years. If your tanks have the common 4 wire "studs through the tank wall" sensor setup, then it's likely KIB. Here's a link to their current version of that panel:
KIBยฎ - M21 Tank Monitor System Panel
Dutch
2001 GBM Landau 34' Class A
larry_cad
I would take out those two screws, and remove the device so I could look at what is on the back. Probably a manufacturer name and model number.
Today is my personal best for most consecutive days alive.
Our Travel Blog
