โOct-14-2014 07:25 AM
โOct-15-2014 01:37 PM
โOct-15-2014 06:50 AM
โOct-15-2014 06:29 AM
โOct-14-2014 03:18 PM
Hybridhunter wrote:
The above post makes no sense at all, for many reasons, but anyhow.....
I concur with the above posters; find a new mechanic, quickly.
โOct-14-2014 02:59 PM
โOct-14-2014 01:03 PM
fj12ryder wrote:ScottG wrote:Would you please explain that statement? You may cause a grease leakage by improper greasing of an EZ Lube system, but how will "loading up the brake shoes with grease" make them run hot?
(snip)
Or, some one is utilizing the EZ lube system and loading up the brake shoes with grease which makes them run increasingly hot .
If anything it will keep them cool by reducing friction when you try to use them. ๐
โOct-14-2014 12:20 PM
davideh wrote:
My questions:
1. Is the wire chafing a possible cause and have others observed this problem?
2. Are wheel bearing failures common and what are the typical causes (besides lack of grease and overloaded)?
3. What additional inspections / maintenance might stop these failures?
Davideh
โOct-14-2014 09:19 AM
(snip)
โOct-14-2014 09:03 AM
โOct-14-2014 08:58 AM
โOct-14-2014 08:38 AM
โOct-14-2014 08:21 AM
kaydeejay wrote:
Might want to ask your tech about that "Hot" wire!
There is no such thing at the hub until the brakes are applied, at which point you WANT them to work.
Rest of the time the wires are either ground or zero volts. Nothing to short there.
So I'm calling B.S. on his explanation!
If it WAS an overheated brake that caused the problem, then it was due to mis-adjustment (too tight) causing them to bind.
โOct-14-2014 07:51 AM
