Which inline circuit breaker?
MP_soldier
clickyI overtightened my circuit breaker connection, and broke it.
It looks just like this one:
If my camper is a 30 amp service, is this cb a 30 amp breaker? I'm trying to avoid a drive to the camper and looking at the label on the cb!
2000 Volvo 770
10 speed Eaton autoshift transmission
Cummins N14
2016 XLR Thunderbolt 420amp Toyhauler
Featuring side and rear deck AND onboard Onan Genny
10 REPLIES 10
wa8yxm
Both Buss and Littlefuse make breakers like that, Some are plastic cased, Some metal, it really matters not
The only thing that matters is the amperage rating that should be molded or stamped or printed on the plastic portion of the case, You might need to remove it to read the amperage.
time2roll
Mex, I have an aversion to self resetting. During an unattended fault how many times will it reset before the thing fails? Do you trust it to fail open?
Good link and with minimal browsing a 50a manual reset is $41.08 shipped.
Switchable can also help during service.
westend
smkettner wrote:
Those auto-reset are junk IMO.
Get a bussmann Hi-Amp 30
http://shop.genuinedealz.com/Marine%20Electrical%20Supply/Breakers
Yes I know it is more money and well worth it to have actual protection.
X2
'03 F-250 4x4 CC
Bonefish
If you look at it real close you will probably fine that it is a 50A DC auto reset breaker. If the old one just quit look for a small pin size button which is the reset button. Our first camper had not-auto reset ones installed.
MEXICOWANDERER
Yet another source
http://www.delcity.net/store/Auto-Reset--Mid!Range-Circuit-Breaker-!-32-V/p_742602
Uh, I had to modify my post, excuse me.
Yet another source at ONE-FIFTH the price!
HiTech
The 30 amp AC service for your RV is not related to the sizing of this DC circuit breaker.
Jim
time2roll
handye9
Those breakers are readily available, but, they do come in different amperages.
You probably need to drive by a few autoparts stores, on your way to the trailer. Pick up a couple 20's, 30's, and 40's. On your way home, return what you don't need.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
enblethen
Amperage would be closer based on the size of the converter and wire size between the batteries and the converter. You should be safe with a thirty or maybe a forty. I am guessing on the discription of rig in signature.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ksg5000
That's a DC auto reset circuit breaker readily found at any auto parts store - I would take the old one in and see if they can identify and replace with identical amp.
Kevin
