Dec-20-2018 12:29 PM
Dec-21-2018 01:48 AM
Dec-20-2018 04:54 PM
groundhogy wrote:
Well, I am still here..
Those are some very good tips and comments. Thank you.
We still have Christmas cookie production running.
She is using the knob to, i guess, bypass the thermostat or sensor/relay. She turns it to total broil and then turns it back to very low. This doesnt let the thermostat decide i guess.
For temperature monitoring, I have a fluke DVM that has a thermocouple input and tells temperature. This oven is like an Amana or Magic Chef or something, but the temperature is also WAY WAY off.
A lot of heat seems to escape from the unit. Maybe from the back. You can put your hand there and feel it. I was thinking it needs some fiberglass stuffed in there. Like maybe they forgot to insulate it.
Dec-20-2018 04:52 PM
pianotuna wrote:
Can anyone tell me WHY they put the pilot light at the back of the oven so we have to get down on our hands and knees to ignite it?
I solved the issue by going electric and never using the propane oven.
Dec-20-2018 04:35 PM
Dec-20-2018 03:50 PM
Dec-20-2018 03:49 PM
Dec-20-2018 03:38 PM
Dec-20-2018 03:12 PM
YC 1 wrote:
You may be able to remove the pan over the heating element to get good access to the pilot flame. In any case be sure the flame is properly aligned below the thermocouple. Mine was misaligned and after adjustment it worked fine.
Dec-20-2018 02:51 PM
Dec-20-2018 02:05 PM
Dec-20-2018 01:54 PM
Dec-20-2018 01:39 PM
Dec-20-2018 01:29 PM
Dec-20-2018 01:07 PM
