Most Likely Accurate:
Contact Keystone with your VIN, they should be able to provide you with the needed info.
Guaranteed Accurate:
Remove your frame and read the label that is hidden inside by the wall. Make a note of the nomenclature & compare it to the info you received. If they don't match call them back with your info. Reinstall the frame while you await the replacement.
This is what I did:
Call Duncan Systems in Elkart, IN (Great Folks) arrange an appointment to have them replace the window. They will do the above and put the new one in when it arrives. If you are insured they will deal with them. The trip is on you though.
George & Cathy
08 Titanium 28E33SA, XM, Honda EU 3000is, Trimetric, RotoChocks, LP Reg. Mod, 2 Gal Accum., WiFiRanger GO2/Mobile
04 Ram 3500 5.9 DRW, PAC PRXB E/B, 4" MBRP SS Exhaust, Gauges, Aux Tank/box, BrakeSmart.
ETCS (ss) USN Ret
