โFeb-04-2021 11:29 AM
โMar-11-2021 04:10 AM
MrWizard wrote:
I am a retired electrician , worked years in commercial residential and industrial, I don't recall any NEC that says a generator installed in a mobile vehicle on land, has to bond the neutral to ground
โMar-10-2021 11:10 PM
โMar-08-2021 08:49 AM
CA Traveler wrote:wa8yxm wrote:And now you know why they should be bonded. Without the bonding both the neutral and hot wires are hot and potentially dangerous. Normally the neutral is expected to very close voltage wise to the ground because of the upstream bonding like in the CG distribution.CA Traveler wrote:
Actually a built in RV generator should have a bonded neutral and ground.
Should have? Say who. Mine did not. Neutral floated. I know cause it "Bit" me.. (Well slight tingle) annoying more than painful. but it very clearly was NOT bonded.
Plus there is equipment that does not work or work correctly on a non bonded circuit. EMS is an example and of course the 3 light tester.
Portable gens are excepted in part because they typically are not necessarily designed for RVs. Some RVs will modify there portable gen for neutral ground bonding.
โMar-08-2021 05:57 AM
โMar-08-2021 02:23 AM
โFeb-05-2021 05:04 PM
โFeb-05-2021 03:44 PM
โFeb-05-2021 03:35 PM
โFeb-05-2021 03:27 PM
โFeb-05-2021 02:59 PM
โFeb-05-2021 02:20 PM
โFeb-05-2021 12:58 PM
โFeb-05-2021 06:55 AM
MEXICOWANDERER wrote:
A generator is a generator.
Anyone who rents anything from 10,000 watts to 1 megawatt gas knowledgable repair people. I would need 20,000 words to erect an analysis troubleshooter which is just too lengthy.
It may be something as simple as a grounded neutral.
โFeb-04-2021 07:02 PM
