โMay-26-2018 03:40 PM
โMay-30-2018 06:13 AM
โMay-30-2018 05:51 AM
BFL13 wrote:
You want to keep above 50% SOC, but that is more like 12.4v with AGMs ...
With the AGMs you are at 12.4 and drop to 11.6 and only get down to 11.3, no alarm. (Actually is better than that what with the lower impedance of an AGM)
โMay-29-2018 10:18 PM
โMay-29-2018 09:07 PM
Lenny K wrote:
Good point about seeing a 150 amp draw vice the 120 amp draw that I am actually seeing on my Trimetric. I have 2/0 wires on my batteries and going to the inverter. I looked up the wiring requirement for the Go Power 2000 PSW and that is what it requires.
โMay-29-2018 08:05 PM
shastagary wrote:
i have the same XPower 1750 plus inverter if it shows the fault red light without anything plugged into any of the ac outlets when you turn it on there is something wrong with it. mine still works good and it has been a good inverter they were made for xantrex and were a good price at the time i bought it from Costco.
โMay-29-2018 07:36 PM
โMay-29-2018 06:48 PM
Lenny K wrote:BFL13 wrote:
If the MSW 1750 would work, you would keep that, but if not you will get PSW. Must be love of PSW--not logical ๐
Note that a 1000w MW on PSW will want its full 1500w input, but only wants maybe 1200 on MSW and cooks a little slower. So if your MSW 1750 is maxed out running the MW now, a 2000w PSW might be too small.
The reason I would keep the MSW if I could get working again for no cost is why throw it away if it's still working.
Since I am unlikely to get it working again the reason for going PSW is that it is an all around better product. I'm also tired of hearing my GFCI humming all the time when I have the inverter on. With PSW I would be able to charge my drill without starting my generator as the MSW burns out the charger.
The PSW will run my microwave at full power which will undoubtedly extend the life of the microwave.
My 1750 MSW ran the microwave without ever kicking out so I think the 2000 PSW should have no problem either.
โMay-29-2018 06:19 PM
โMay-29-2018 05:44 PM
pianotuna wrote:
Hi,
I wish Can Tire did a PSW larger than 1000 watts.
Since they don't, I'd go with Samlex or Go Power.
I did have wonderful results with a Cobra MSW intended to run motors.Lenny K wrote:
They are a good buy, but if I don't get this one working I'm going to go with a 2000 pure sine.
โMay-29-2018 02:55 PM
โMay-29-2018 02:18 PM
โMay-29-2018 09:35 AM
โMay-29-2018 07:45 AM
โMay-28-2018 10:55 PM
โMay-28-2018 10:50 PM
fischer wrote:
Found when I searched for xpower 1750 manual. The manual states what the light means
