โJul-29-2009 05:39 PM
โAug-30-2012 09:30 PM
haroldpe86 wrote:
Here's mine a male-male- threaded adapter, some teflon tape, and plastic 1/4turn valves. Very simple and effective mod.
โAug-30-2012 06:39 PM
โAug-30-2012 03:22 PM
โAug-30-2012 02:29 PM
camp4ever wrote:
Did you tephlon tape it??? Looks good!!
โAug-30-2012 11:27 AM
tracyb1101 wrote:
Well I got my low drains changed out thanks for the help and advice ,once I knew what I needed it was easy to do..as you can see I needed the nipples to thread in but it works nicely...Thanks everyone
โAug-29-2012 01:41 PM
โAug-27-2012 07:07 PM
popeye59 wrote:
I can find the water tank drain under the Roo, but as far as any drain valves inside, nope. I'll crawl under there again to see, but if this is only to help winterize, I blow air through the lines so I'm not too concerned about lines freezing.
โAug-27-2012 06:57 PM
camp4ever wrote:tracyb1101 wrote:
ok here are my low drains I went to Menard's the other day in search of the 1/4 values and they had them.. the guy there showed me how they work using the same type of tubing I had. My question after leaving the store of course was do I need to cut off the bottom where the plugs are now because the the tube he demonstratedhow they work did not have the fitting that I have on mine right now it was just the tube. I have included a photo to what I am referring to.
My low drains![]()
Thanks VJK & Tracy B
Get the 1/4 turn valves that have a male fitting that will screw into your existing. Just use some tef
lon tape
โAug-27-2012 06:52 AM
My low drains![]()
โAug-27-2012 05:44 AM
โAug-27-2012 05:10 AM
โAug-26-2012 04:28 PM
โAug-26-2012 03:08 PM
popeye59 wrote:
Not to appear overly ignorant, but what do the low drains drain? I obviously don't have any in my Roo 233S, but am curious in case we upgrade.
โAug-26-2012 05:06 AM
โAug-25-2012 09:26 PM
