12 volt electric blanket
Roadlover
I'm trying to locate a queen size 12 volt electric blanket but not having much luck. People talk about them but the closest I find are electric car blankets that are only 42x58. Thanks
"The Journey is the Destination"
2015 GMC Denali 3500 DRW Duramax/Allison
TorkLift Talon Tiedowns, StableLoads and FastGuns with Locks
2012 Arctic Fox 1150 with Dry Bath with Fox Landing and Wobble Stoppers
29 REPLIES 29
naturist
NRALIFR wrote:
ggadwa wrote:
Bummer its only 36 inches wide. Seen any 12 volt ones that are wider???
GARY
Electrowarmth used to make a queen sized version. I have one and like it a lot, but I think there's a reason they don't make any larger than twin sized any longer. I suspect the larger pad was pushing the limits of the standard 12v sockets found in auto and RV use. The plug Electrowarmth uses on the end of their cord is a good quality phenolic, but plug it into a cheap socket that doesn't hold it tight enough and it will get hot. When I noticed that on mine I replaced the Elecrrowarmth 12v plug with a Marinco plug and receptacle on a dedicated circuit with 6 gauge wires.
My 12v pad in the camper works just as well as my 120v pad at home. If mine ever needs replacement, I intend to buy two of the twin size pads and sew them together to make one pad of 60"x72", which is perfect for a queen mattress. The two twin pads would be running across the width of the mattress, but that's OK. You typically want the leg/feet area to be warmer than the chest area anyway, and the head area to not be heated at all. I'll have to add another receptacle since there would be two controls. As far as I'm concerned the best things about the Electrowarmth pads are the analog control, and no expensive PSW inverter required.
When we travel in the winter, I run it on a low setting while we drive to keep the mattress over the cab from turning into a block of ice. I've also got heavy gauge charging wires running from the truck alternator, so it's able to keep up with the draw from the mattress heater.
Hey, the Electrowarmth 12 volt queen mattress pads appear to be available again! http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28164671/p/1.cfm
NRALIFR
GARY
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
scottz
Jfet wrote:
Costco has a queen size electric mattress pad for about $60. It is 115VAC and comes with 2 digital controls. I have not measured the current draw but plan to put it on a kill-o-watt meter one night and see how much it consumes.
If it runs about 50% duty cycle and consumes 200 watts, then that would only be around one group 27 battery charge per night. With solar as cheap as it is, that should be rechargeable during the day assuming you have 500 to 1000 watts of panel.
(I would power it using an inverter which runs at 90% efficiency and the waste heat just warms the interior of the camper anyway.)
Wow, your $60 solution got really expensive when you added the 500-1000watts of s solar, even with solar as cheap as it is.
Jfet
ggadwa
GARY
HAM RADIO Operator since 1964 'W7FSI'
EAGLE CAP 2011 950 CUSTOM BUILT by the great folks at LaGrande Oregon
2012 FORD 350 XLT 6.7L Diesel 4x4 Super Cab with lots of stuff
Kidoo
I wish I have seen this 12 volt double bed mat before!
Monaco Cayman 34 2003, Cummins 300HP
Bigfoot 2008, 10.4, F350, 2006, Diesel 6.0, Black, 4x4, long box, Air lift, Rancho 9000, Rear sway bar.
narcodog
scottz wrote:
narcodog wrote:
http://www.electrowarmth.com. I'll take mine over a blanket anytime. It warms the mattress not the air above where you laying. I have two and my wife and I can use them at the same time and in the morning still have plenty of amps in the battery's. I've used mine for four nights in 20 degree weather before having to recharge. That's in conjunction with everything else. Two 110 amphr battery's.
I really can't see the advantage of one a blanket. Two having to buy an inverter. Or using 110 system.
Thanks for sharing.
I assume you bought the 12v model here.
It is cheaper, $80 at Amazon. Pretty good reviews too!
I bought the first one from them the last one I bought was from Ebay. I did buy the 12v model.
scottz
Thanks for sharing.
palmwhit
We've used one since '07! Goes under the sheet between you and the mattress (as others have said) and works great! I have two group 29's and we have never had a issue with the power draw. We have used down to -6f OAT with the furnace set to around 55. Batteries held up fine. An electric blanket on top just will not do anything for between you and the mattress, so you're still uncomfortably cold at the point of contact with the mattress. You don't really need one to cover the entire mattress, just the main torso and legs, you're noggin is on a pillow (and probably hollow anyway). I think we paid around $70-80 but it's been well worth it.
narcodog
bobndot
scottz wrote:
bobndot wrote:
scottz wrote:
Can you guys who like your 12v blanket/mattress covers post links to them?
http://www.12volt-travel.com/
Doesn't help, reread my post.
http://www.12volt-travel.com/12-volt-electric-blanket-p-5631.html
scottz
kohldad
Glad this was brought up. I need to get one before next winter season. I need one to take the chill off the feet area as I have poor circulation. Once I get that area warm, my feet can keep it that way. And yes socks help, but still have some problems on very cold nights.
Would definitely be worth the 2-4 amp/hr drain off the battery.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
ggadwa
Use whatever you like but in our case 4 amps for 30 minutes makes for a nice cozy bed and my two 6 volt Trojan Golf Cart batteries are not bothered by it either...We are Happy Campers.
We TC in Winter lots.
Gary & Laurii
