12V Portable air compressor
MorMJS
Im looking to add a 12V air compressor to my list of things we carry when we camp in our trailer. There are SOOOO many of them on the market I figured I would ask here what brand or model you guys are using and would recommend?
TV- 2009 Dodge Ram 2500 crew cab 4x4 6.7L CTD, 2" lift on 35x12.5" Toyo MTs, S&B CAI
New TT 2016 Keystone Bullet 272BHSWE Fastaway E2 WDH, Tekonsha Primus IQ brake controller
Old TT- 2014 Rockwood MiniLite 2502s
25 REPLIES 25
time2roll
If it has a cigar plug it is weak.
A good 12v compressor will have battery clamps or hardwired.
MV-50 works well for me.
n7bsn
Tequila wrote:
The "Slime" works well.
I've seen tire shops (good ones) refuse to attempt to repair tires that have been slimed
I do use Green Slime in my cart, wheel-barrel, lawn-tractor and bicycle tires though.
I echo the "buy a good one". I did and it will pump my 80 psi tires in less then an hour :B
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Tequila
Bigbird65
I wanted a real air compressor, not one of the $12 toys. I bought this MV50 from Northern tool. Of course it is made in China but it works really well. It stays in my camper. Check it out.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
chr_
I have one of these with a small tank...
Forget the el-cheap-o ones from wallyworld.
Buy one of these, a tank from HF tools, and wire it in somewhere with a hose long enough to reach all the tires on the TV and Trailer. 100% duty cycle means it will not******out filling an empty tire, and hardwire or battery clips mean it will not melt the cigar lighter plug.
-CHR$
1996 Safari Sahara Edition 35' Diesel Pusher. Just getting the Solar stuff started.
GrandpaKip
150 psi compressor from Harbor Freight. Had it 2 years, works well so far.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
MorMJS
dahkota wrote:
Depends on what you need it for. The one posted above would be good for small cars, bikes and air mattresses, but not much else.
Sorry about that, I would be using it for my truck tires(60-65psi)my trailer tires, kids bike tires, maybe to inflate a raft or float tube for fishing.
FrankShore
I use the one I posted above to bring my trailer tires to 50 psi!
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
DB2BRMI
we have a Viair 330P which will do our truck tires.
You can go smaller such as the Viair 90P, but inflation and recovery take longer.
____________________________________________________________
Ditto what this guy says.
DB2
dahkota
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
FrankShore
http://www.walmart.com/ip/RAD-Sportz-12-Volt-Electric-Co-Pilot-Air-Compressor-w-Gauge-for-Bike-or-Au...
This should do the trick
2014 F-250
