1500 curb weights
Jbird
Ive given up on finding the answer to a relatively simple question online or on the forum here. Hope somebody can help me:
What is the real ,actually using it, curb weight of a late model 1500 pickup? The factory brochures give GVWRs and payloads,but the latter is not at all helpful if one doesnt have some ballpark idea of curb weight. I find one F150 owner weighing in at 6600; one online site suggests any where from 4900 to 5300 for a GMC. That's quite a range!
36' Mobile Suites,Chev 3500 Duramax
16 REPLIES 16
JIMNLIN
Fleet Ford specs show a 2020 F150 reg cab..3.3 gas engine..2wd..122" with a 4069 lb base weight.
Same specs shows a F150 supercrew..4wd..156" wb with a 5335 lb base weight.
Thats 1266 lbs difference so its not hard to see a fully loaded supercrew HDPP with its heavier frame all the options may weigh in the 5800 lb range. The F150 has three different frame material thickness and sizes.
Ram and GM 1/2 ton trucks don't have as many different size 1/2 ton trucks as Fords F150.
Grit_dog
Navigator
Navigator
Why’s it matter? Counting how many cans of soup or beer you can put in the camper?
Trying to think back to the last time I cared what any truck weighed.....can’t think of any.
But if you want to know, look at the towing guides. They have curb weight or gvw and payload.
Bout as close as we can get without asking personal questions like how much does your wife weigh.
blt2ski
Moderator
Moderator
Heavy trucks you all have. My 2000 C2500 wieghs 4800 off the line. Altho arou d 5300 with spray in line-x liner, a mesh walled ladder pipe rack...
I have three chargeable options. Auto trans tow pkg, hitch only at the time, trim rings.
Two others on here had 05 GM dually diesel crew cabs. One sighed 7200, a stripped rwd. My LS 4x was 7300, bertp, have not seen him post in awhile, his was a leather interior, it was somewhere north of 7700 sitting there empty.
So yes, it is possible for some rigs to have upwards of 500-700+ lbs difference between a very stripped model, and a full leather pkg with a diesel motor.
I've seen some red reg cab 1500s listed with 4800-5000 lb empty wts like my C2500. Crew cabs pushing 6000 lb full leather, power seats etc.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
We_ll_See
My 2017 Crew cab f150 weighs about 4,950 pounds. It is a loaded XLT, 5.5' bed 4wd 2.7 eco boost. GVWR is 6,500 pounds so the payload is just over 1,500 pounds. Fords use a bit more aluminum in their half tons so I would expect the Ford F-150s would be a little lighter than comparable half tons from other brands.
Jeep and Explorer
Jbird
Thanks all. Learned a lot. And Mooky and Lliddis Chevs really help with what to expect looking for a late model Chev or GMC.
mooky_stinks
I've weighed my last 3 1/2 ton Chevys and they've all been right around 5500 lbs.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
Groover
6600lbs for a F150 sounds more like the gross weight than the curb weight. I have a fully loaded 2016 F150 4wd CC 6.5ft bed and its curb weight is about 5,600lbs. I don't think that you there are enough other options to add up anywhere near an extra 1,000lbs.
wing_zealot
Boomerweps
gmckenzie wrote:
My 2015 has a GVWR of 7,600 lbs and a payload of 2015, so I assume the curb weight is the difference? But I'm never sure what they take into consideration for the payload numbers.
Known values.
Full tank of gas
Some include 150# driver.
Weight of vehicle when it left the factory.
Subtract the above from GVWR.
Remainder is factory Load capacity or payload.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
MFL
Nomad II
Nomad II
You are correct on the curb wt as it left the factory. Just a thought... to show that axle wt ratings matter most.
F150 with HD payload pkg, with 2,400 lbs payload
F250 with diesel engine, only having 2,100 payload
Which truck can carry the heaviest load???
Well of course the 250, due to having waaayyy more axle/tire capacity!
Many 1/2 tons run out of axle capability, about the same time as payload rating is reached. In some cases sooner.
Jerry
JIMNLIN
Actually 1/2 ton trucks gross weights across the brands will vary much more than that. Same with one tons or 3/4 ton trucks.
New trucks have a shipping weight as it leaves the factory which can be on the window sticker...sometimes.
If you need a weight to register a truck then use its GVWR or the sum of FAWR and RAWR.
If your trying to figure how much a track can safely carry then curb weight minus its GVWR numbers isn't always good/safe number to use for a newer pickup truck that carries its payload over the rear axle.
gmckenzie
2015 GMC Sierra 4x4 CC SB Max Trailer
2010 Cougar 30RKS
stickdog
If your looking at new trucks ask the sales person to see the shipping ticket. That's the wt sans fuel other than the 2-3 gal shipped with and any dodads a dealer may have added.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Lwiddis
My Silverado weighed 5288 pounds when I picked it up.
