โDec-18-2014 02:39 PM
โDec-27-2014 07:23 PM
โDec-27-2014 06:32 PM
Roadtech wrote:mamasmax wrote:
You left out the part where you went out and drove a truck with each tire/rim combo to decide for yourself which one you liked better.
Unfortunately, there are no 20" wheeled 2015 trucks at either Chevy or GMC dealers in my area.
โDec-27-2014 04:11 AM
โDec-26-2014 12:12 PM
โDec-26-2014 06:05 AM
โDec-26-2014 05:07 AM
โDec-26-2014 04:48 AM
โDec-24-2014 07:03 PM
MM49 wrote:wintersun wrote:
When I was looking for higher load rated tires the size of the rim made a very big difference. Most high capacity tires are made for delivery vehicles with smaller rims and DRW or for large trucks (22.5" rims).
The sidewall profile is a factor with a truck if you plan to haul any amount of weight. It will take less of an impact to break the bead of the tire and provide an instant flat tire. The larger rims do result in tires that provide better fuel economy as there is less sidewall flexing that wastes fuel. This is trivial for a truck owner but a very big deal for the truck manufacturer who is very much concerned about meeting federal CAFE fleet standards for fuel economy.
When I was looking at new trucks I found that the trucks on the dealers' lots with 20" wheels all had a lot lower payload rating than the trucks with the 17" or 18" wheels so more changed than just the tires on these GM/Chevy 1-ton SRW trucks.
The option 20" tire on the RAM 2500 is 285/60/20 with a load rating of 3840lbs???????????????????????????????????????????????
mm49
โDec-24-2014 09:53 AM
โDec-24-2014 07:09 AM
โDec-23-2014 07:21 PM
N-Trouble wrote:
Hmmm. 20's were only an $800 option on my 2012 GMC SLT trim.
Your right about the 3500s though, you couldn't even order one with 20's because they don't have a high enough weight rating to match the 3500s payload.
โDec-23-2014 06:39 PM
โDec-23-2014 06:29 PM
srt20 wrote:N-Trouble wrote:srt20 wrote:
My bud has a 12 Dmax 3500 with factory 20s.
It didn't come that way from the factory... Either he or the dealer put them on.
It did come with 20s from the factory. Even got all 4 replaced under warranty for clearcoat peeling.
2012 GMC Denali 3500 4x4 duramax Crew cab.
โDec-19-2014 06:51 PM
