19.5 vs. 22.5 - anybody have input and/or pics on a Ford?
Boatycall
Morning,
Just in the investigation stages of doing a rim/tire upgrade. I've read a little here and there on the net, looking at the pros/cons of 19.5 vs. 22.5. The first I'm seeing is 19.5s is available without adapters, 22.5s aren't.
Also wouldn't mind hearing comments of stock vs. 19.5/22.5.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
10 REPLIES 10
jimh406
elkhornsun wrote:
I would go with DRW instead.
It looks like already has one. 😉
garryk6
I went from 16's to 19.5's on my F350 SRW. I have 265x70x19.5 tires that are a bit of an AT tread. They are very heavy duty sidewall, and fit my leveled 2002 F350 with no rub. They are a 34" tall tire. Reduced my sway by a lot!
I just bought an f700 box truck that came with 22.5 rims and tires. They are much larger, though both have very thick sidewalls (almost an inch thick sidewall!)
So having close view of both, I would stick with the 19.5's since they are a bolt-on. Any adapter to enable the use of 22.5's would add strain to the bearings not even factoring in the added weight.
Hopefully that helps in your decision making.
Best regards, Garry
Garry K
Wife + 4 kids
Retired Military Family.... Alway's on the move....
2002 F350 CCSB 5.4 6spd 4x4 in AK
1966 Avion C-10 Truck Camper
elkhornsun
Tire options are already very slim with the 19.5. Going to the 22.5 size leaves you with heavy truck or bus tires that are highway tread only and the ride will be very hard with you and your passengers able to feel every bump in the road. I would go with DRW instead.
jimh406
19.5s have a lot less profile as well for the height. I think 22.5s would likely be hard to use without going tall.
Bedlam
Moderator
Moderator
mooring product wrote:
Im going to go with 20" direct bolt on with some Nitto terra grapplers in a LT275/65R20 E126R
http://aewheel.com/eagle_alloy_wheels.cfm?id=1945&cat=474
You should just go with a 19.5 direct bolt on...mind you the 10 lug looks much more "bad aXX"
Be aware that those rear rims are only rated for 2350 lbs each giving you 9400 lbs capacity on your DRW rear axle. The tire rating of 3750 lbs is overkill for that rim.
Nautique200
Same setup I'll be looking into. Make sure and post some pictures when you get them mounted up. Good looking wheel and they look easy to clean!
2016 Ford F450
2015 Arctic Fox 1150
2009 Trails West Warm Blood Trailer
Boatycall
I bet ya they'll probably look great, but in my case, I'm not going for looks, strictly function. I want the stiffer sidewalls and the "piece of mind" of commercial tires. I've heard(but not confirmed) that commercial tires have less give, helping a lot with sway control.
One drawback I have heard is stiffer ride when empty, which is fine because I seldom drive my truck unless it's doing something a truck has to do. Otherwise I have a couple other vehicles I drive.
msiminoff
The only Fords I have seen with 22.5" wheels are from EarthRoamer.. They require an adaptor and body modifications and/or lift in order to avoid rubbing.
If you currently have a dually and want to run SRW then I suggest you take a look at the 19.5" wheels from Hutchinson. Note: these are 10-bolt wheels and will require an adaptor.
If you want to continue to run DRW then there are many direct bolt-on 19.5" wheel options available from companies like Vision Wheel and American Force.
Cheers
-Mark
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
mooring_product
Pete
2012 RAM 3500 Mega DRW. Stable Loads and Torklift tiedowns.
2006 Lance 881 Max.
Bedlam
Moderator
Moderator
Isn't a 22.5" rim kit going to leave you with a 35-37" tall tire? You may be able to stuff 35's in your wheel well, but I suspect even those may need a lift to not rub at full lock. Do you really want to raise the COG of your setup? Do you tow with your TC on the truck? Going to a 35" or taller tire may require gearing changes in your axles.
There are plenty of 19.5" rim choices that will give you 4500 lbs or more capacity per wheel in a 33" tall tire. This option would cost you around $3000 for a set of six rims and tires mounted and balanced with new lug nuts and center caps.
