2 dirtbikes in standard bed while pulling trailer?
katoom400
my new Superduty has a 6'8" bed, and I've always owned long beds in the past so this was never an issue.
when I travel to dirt bike events I have the need to have at least 2 bikes in the bed of the truck. 1 will fit without a problem on a diagonal, however 2 need to be in straight and I can not close the tailgate this way.
one option is to take the tailgate off, but I would rather not.
www.vehicle-systems.com/tailgate.htm
has anyone used a device such as this to keep the tailgate partially closed/open and does it have the clearance needed to clear a travel trailer? in the pictures they only show it being used with a flatbed trailer where the only concern is the tongue jack and not the gate hitting the trailer in a full lock turn?
15 REPLIES 15
wolverine68
If you put the front tires into the corners of the box and bring the rear wheels together, the tailgate should close.
04 Chev LLY Duramax
07 Desert Fox 24AS Toyhauler
Bikes and quads to fill the toyhauler
katoom400
We Cant Wait wrote:
No I'm thinking of MC's, most only require the removal of the axle bolt to remove the front tire.
way too much work on a motorcycle, if I was going across country and that was my only option...then maybe, but looking for something quick and simple, I'm going to order the tailgate latch bars
We_Cant_Wait
katoom400
We Cant Wait wrote:
Dismount the front tires on the bikes, and make a rack for the forks to mount in, this will give you the clearance to shut the tailgate completely.
umm, you must be thinking of bicycles, that would be WAY too much of a hassle for a motorcycle..
We_Cant_Wait
Hannibal
When I used to take my Harley in the bed with our TT in tow, I'd take the tailgate off for the same reason. I used four new straps and a rope for backup. The bumper was perfect height for the planks to be level with the bed for loading and unloading the ol' sow.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
GWolfe
Hauling my ATV in my 5'5" bed truck I am unable to close the tailgate as well. Like coolbreeze01 I use a ratchet strap from the ATV down to the bumper to hold the tailgate up, no clearance problems at all.
2005 Sun-Lite Eagle
2011 Silverado
jareddustin
i have just used some tie downs in the past, not as fancy as the system you put but it works just fine
discovery4us
I use DG tailgate supports which work the same as the ones pictured when I haul my RZR and am very pleased with them.
mich800
downtheroad wrote:
Looks like a good idea...but, why not make your own from a couple of lengths of chain and carabiners .
I like the fact it creates a rigid closure. No tailgate bouncing. Looks clean and simple.
coolbreeze01
Hauling my RZR, my gate wouldn't shut, so I raised it up against the tires and used simple tie-downs to keep it up. The system you show looks better.
No interference with the trailer and tailgate.
2014 Sandsport 26FBSL
katoom400
Bedlam wrote:
They make a quick release for the tongue jack. Check into that and you may be able leave your tailgate down.
http://www.campingworld.com/shopping/item/jack-e-up-removable-jack-bracket-black/77463
the tongue jack is not the real concern for me, but I'd like to know if the use of the tailgate latch bars is enough to keep the gate from kissing the trailer on tight turns?
a bed extender would nice, but the only way would be to use a hitch extender which drastically limits the tongue weight the hitch can handle. So I'm looking for other options.
downtheroad
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Bedlam
Moderator
Moderator
