โAug-28-2014 02:14 PM
โSep-03-2014 04:25 PM
โSep-03-2014 09:06 AM
Anson wrote:
Thanks everyone for the replies. we ended up finding out that the turbo does not need to be oiled up before starting it.
โSep-02-2014 03:52 PM
โAug-31-2014 04:13 AM
Sport45 wrote:eHoefler wrote:
I use a socket on a breaker that fits the turbine nut on the intake side. While using the socket on the nut, I have someone else start the truck, I keep the turbo from spinning for about 30 seconds. This allows oil pressure to build and fill the galleys on the turbo without spinning, then let it go.
If you do this I recommend shutting the engine down after the 30 seconds and not removing the socket until the turbine quits trying to spin. I wouldn't want to take a chance on the socket slipping off the breaker and bouncing around in there.
Pre-lubing during assembly should suffice.
โAug-29-2014 08:23 AM
โAug-29-2014 04:57 AM
โAug-29-2014 04:47 AM
โAug-28-2014 06:50 PM
โAug-28-2014 04:38 PM
โAug-28-2014 04:34 PM
โAug-28-2014 04:25 PM
โAug-28-2014 03:22 PM
โAug-28-2014 03:17 PM
โAug-28-2014 03:06 PM
