โJul-14-2017 09:15 AM
โJul-16-2017 04:25 PM
Swell1 wrote:
There should be sticker inside the door frame that tells you what its rated for.
โJul-16-2017 04:24 PM
โJul-16-2017 03:07 PM
โJul-15-2017 06:52 AM
โJul-14-2017 12:48 PM
โJul-14-2017 12:15 PM
โJul-14-2017 11:30 AM
lawrosa wrote:
I have the 1500 with 4 speed 3:42 rear and can tell you I dont want to tow more then I have know at about 5500 lbs fully loaded. I added a large trans cooler.
The stupid 4 speed is my limiting factor.
I would look a travel trailers in the 4000-4500 lb range empty
โJul-14-2017 11:09 AM
โJul-14-2017 10:02 AM
datric.johnson wrote:
I have a 2010 Chevy Silverado 5.3L V8 6spd. 2x4, 3.08 axle ratio. GVWR: 6800lbs. I have the weight distribution hitch which is rated up to 10500 lbs. I also have the engine oil and transmission oil coolers.
โJul-14-2017 09:50 AM
