โJan-23-2017 12:29 PM
โJan-24-2017 11:40 AM
โJan-24-2017 11:32 AM
Cummins12V98 wrote:
Be sure to remove the intake as shown with steel pipe attached, much easier than separating the rubber hose from metal pipe.
โJan-24-2017 08:43 AM
Me Again wrote:Couple more questions:Ron3rd wrote:1. What does RAM say?IdaD wrote:Good point, and on another topic, Dodge instructs NOT TO PREFILL your fuel filters when replacing.Cummins12V98 wrote:IdaD wrote:Do you pre fill as Cummins suggests?
I use 5w-40 Rotella T6 synthetic because it's required in my area due to winter temps, though I run it year round and plan to do so going forward. It runs about $18/gallon on Amazon subscribe and save. I also use the Stratopore fleeguard filter.
As far as changing the filter, I got the filter end wrench from Geno's that attaches to a ratchet and it works well. Once I get the filter loose I drop it into a freezer bag, seal it up and pull it through the hole. Then slide the new one through the hole, spin it on and good to go. It's not the most convenient location but it adds very little to the time or difficulty of the job.
Nope, never have. It's never caused any problems with any vehicle I've been around and I was actually taught early-on not to pre-fill due to the potential of adding contaminants on the back side of the filter. I did do some research on it after I bought this truck and found nothing that convinced me it was a good idea - if anything I found more that recommended not doing it. Truthfully I don't see it as a significant deal either way.
2. What does Cummins say?
โJan-24-2017 07:19 AM
Wild Card wrote:
never prefill you fill it up with unfiltered oil on the outgoing side of the filter, same with fuel filter. It was an old way of doing service.
I spin my filter off and let it rest carefully on the crossmenber. I stick my finger down in the threaded hole and pull the filter out through the wheel well...I have yet to make a mess with the filter.
โJan-24-2017 06:35 AM
โJan-24-2017 06:24 AM
โJan-24-2017 06:14 AM
โJan-24-2017 06:08 AM
Nope, never have. It's never caused any problems with any vehicle I've been around and I was actually taught early-on not to pre-fill due to the potential of adding contaminants on the back side of the filter. I did do some research on it after I bought this truck and found nothing that convinced me it was a good idea - if anything I founded more that recommended not doing it. Truthfully I don't see it as a significant deal either way.
I didn't pre fill before the Cummins, but the filter holds almost a full quart of oil, just too much fun time to fill dry.
โJan-24-2017 06:06 AM
โJan-24-2017 06:05 AM
โJan-24-2017 05:41 AM
โJan-23-2017 06:47 PM
โJan-23-2017 06:12 PM
โJan-23-2017 05:51 PM
โJan-23-2017 05:48 PM
Ron3rd wrote:
I don't have a 4x4 and all I saw in the manual is to lube the front tie rod ends. Am I missing somethig?
