Camper "nose" condensation
Kayteg1
Due the house sale we have to stay in the camper in winter and condensation is huge problem.
Bathroom window and slide windows do have internal gutters, that fill up with water and we have to sponge it on daily basis, but the biggest problem is the nose, where condensation from front window drips down behind the matters, getting our pillow wet and mildew growing.
Occasionally I lift the mattress (it is upgraded, heavy sucker) and stick heater under for drying, but I am trying to figure out a way to keep the matters not sliding under the window.
We do have about 5" clearance on the bed, but with normal movements the mattress slides and the pillow will go against dripping window.
Ideal would be plastic cage, wedge shaped that would lift the end of the mattress and keep air circulation under it, but such don't exist.
I am thinking about buying 6" or bigger drainage pipe and drill big holes in it for good air flow.
Any other ideas?
22 REPLIES 22
Wardster
I use the Hypervent beneath the entire mattress to allow for air to circulate under there. This is a proven method for dealing with condensation issues in that and other areas. When the three of us are in the TC, we use a dehumidifier to take care of moisture if we have shore power or we crack a window.
2016 Northern Lite 8'11" Q Classic Special Edition
2003 GMC 2500HD Crew Cab 4x4 - Duramax/Allison
Kayteg1
GeoBoy wrote:
For under the mattress use HyperVent. Go to defender.com for the best price and quick service.
That is what I was looking for. Thanks.
Sold by a foot, so double length will make nice quote, but I need it only on pillow side.
GeoBoy
Wardster
x2 on the dehumidifier.
RickW
Kayteg1 wrote:
At this point I am thinking about buying one of those and fit it under the window. Actually I might use 2 of 4" dia pipes bolted vertically to match the mattress thickness. In extreme situation computer fan mounted on the end should help.
Maybe I also will get 2 or 3 pipes in 3/4" dia and drill similar holes, to fit it under end of the mattress. That will add ventilation directly under the "wet" end and give us raise in pillows area as well.
Obviously for full winterizing -covering the window with insulation will be the must, but I don't plan to go that far/cold.
What you guys think?
I think you have a great idea there.
Rick
04 GMC 1500 4X4X4, 04 Sunlite SB
jimh406
I'm not sure why you wouldn't want to use the solution that Buzzcut1 suggested instead of working around your problem.
BTW, I used reflectix in cold weather as well and have no issues with condensation. I put mine in the window at night and roll up and put in a light nylon bag for during the day. It also minimizes the time that the furnace runs and makes the TC more comfortable.
Kayteg1
billyray50
I purchased a product dry mesh I few years back for a Previous TC that corrected any condensation under mattress even in hot days with the AC running but could not find a distributor now in the US so I used a 4 x 8 pink 1" foam board from home depot under mattress helps tremendously but venting is really the key. I used reflectix on thermos pane windows and condensation still was an issue without venting with when using campers propane furnace. Hyper vent material I read also works good for rvs and boats but is expensive.
ticki2
A couple of angle brackets screwed to the floor will stop the mattress from sliding against the window , use nails if it is carpeted . Don't let the blankets fill the gap , it needs air circulation . A small computer fan will also help . Insulate the window . It's all about the dew point .
'68 Avion C-11
'02 GMC DRW D/A flatbed
RickW
I can't visualize exactly what you want, but you can get a 4 inch diameter perforated drain pipe for a few bucks. One or two pieces should space the mattress away from the wall.
Rick
Buzzcut1
Nomad II
Nomad II
home depot, get a $10 roll of reflectix some double sided velcro and a pair of scissors. cut to fit and stick in place, fast easy and cheap plus it works.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Joe417
We have a couple of what we call swim noodles in front of the mattress. That keeps it from sliding forward against the front wall.
They cost a couple of dollars at Walmart. And you can cut them to any length you want.
Joe and Evelyn
AnEv942
Maybe couple of layers foiled bubble wrap, reflextix as mentioned. Most hardwares sell by the foot, easy inexpensive non permanent, all you'd need is some scissors and tape.
Our nose window, air just doesnt move around it, everything else can be bone dry and waters running down it. It has an inner channel, was always going to insert a piece of plexiglass to see if it'd help-just never have.
Spacer- something like foam pool noodles to keep mattress away from wall?
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
Rubiranch
Am I the only one who sleeps with their feet by the window and my head towards the door?
I like the dehumidifier idea myself.
It just seems best to eliminate the problem rather than to just cover it up.
Camp Host, from the other side.
