2016 CTD 6.7 oil change questions
Ron3rd
Getting ready to do the first oil change on the new CTD. I've watched all the youtube videos regarding the PITA oil filter removal and spillage avoidance. Just wanted to get some feedback on how others are getting the filter out of the very small window provided in the fender well. Some use the Gino's cap off tool to seal the filter at the top, but that looks like a hassle. Others drop the filter into a zip lock bag or trash bag. What are you folks doing?
Also, Costco has a good deal on on 3 gallons of Chevron Delo 400 SDE oil ($28.99) and would like to know if others are using this oil.
I'll be using the Stratopore filter by the way.
TIA
Equilizer Hitch
Honda EU2000
66 REPLIES 66
Wills6_4_Hemi
Here in N.C. on all 2016 Dodge HD trucks the first 4 oil changes are free ( GAS OR DIESEL) if done within 2 years. Might want to look into it.You can use any dealership also. I just done my first one today.
Ron3rd
Cummins12V98 wrote:
Be sure to remove the intake as shown with steel pipe attached, much easier than separating the rubber hose from metal pipe.
Cummins, is that how you do yours? I've looked at both ways (coming through the side, etc)
Equilizer Hitch
Honda EU2000
otrfun
Me Again wrote:
Ron3rd wrote:
IdaD wrote:
Cummins12V98 wrote:
IdaD wrote:
I use 5w-40 Rotella T6 synthetic because it's required in my area due to winter temps, though I run it year round and plan to do so going forward. It runs about $18/gallon on Amazon subscribe and save. I also use the Stratopore fleeguard filter.
As far as changing the filter, I got the filter end wrench from Geno's that attaches to a ratchet and it works well. Once I get the filter loose I drop it into a freezer bag, seal it up and pull it through the hole. Then slide the new one through the hole, spin it on and good to go. It's not the most convenient location but it adds very little to the time or difficulty of the job.
Do you pre fill as Cummins suggests?
Nope, never have. It's never caused any problems with any vehicle I've been around and I was actually taught early-on not to pre-fill due to the potential of adding contaminants on the back side of the filter. I did do some research on it after I bought this truck and found nothing that convinced me it was a good idea - if anything I found more that recommended not doing it. Truthfully I don't see it as a significant deal either way.
Good point, and on another topic, Dodge instructs NOT TO PREFILL your fuel filters when replacing.
1. What does RAM say?
2. What does Cummins say?
Couple more questions:
1. If the oil filter is not pre-filled on a Cummins 6.7, how long does it take for the oil pressure to normalize?
2. How long can a Cummins 6.7 run with little to no oil pressure without sustaining any damage?
cummins2014
Wild Card wrote:
never prefill you fill it up with unfiltered oil on the outgoing side of the filter, same with fuel filter. It was an old way of doing service.
I spin my filter off and let it rest carefully on the crossmenber. I stick my finger down in the threaded hole and pull the filter out through the wheel well...I have yet to make a mess with the filter.
Exactly , was told by a tech at a Ram dealership thats the way he does it, but I have yet to try it now with having the Genos cap.
They looked at me funny when I mentioned taking the turbo intake off 🙂 Which is the way I did it the first two times, now I know why they looked at me funny.
But I do prefill .
larry_barnhart
Many vehicles have the filter horizontal so pre filling can not be done. Doesn't seem to be that necessary to me. what am I missing?? Maybe less mess.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
A couple minutes to remove the intake and this is what you are looking at. Very easy to R&R.
No special tools needed.
Cummins12V98
rhagfo wrote:
Nope, never have. It's never caused any problems with any vehicle I've been around and I was actually taught early-on not to pre-fill due to the potential of adding contaminants on the back side of the filter. I did do some research on it after I bought this truck and found nothing that convinced me it was a good idea - if anything I founded more that recommended not doing it. Truthfully I don't see it as a significant deal either way.
I didn't pre fill before the Cummins, but the filter holds almost a full quart of oil, just too much fun time to fill dry.
Yes very true. Actually one quart will fit with room to spare just let it settle for a bit.
Cummins12V98
UH.....my answer is to pre fill!
Cummins12V98
There is NOTHING wrong with pre filling as long as you don't dump anything into the filter. You would have to be blind and very careless to let that happen. Cummins recommends doing it. I have pre filtered EVERY filter that I could with WELL over one million miles driven and serviced with no issues.
Wild_Card
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
Me_Again
FishOnOne
I admire this guy's attempts to come up with a clean process to change the oil on these trucks which require too much effort. As for the prefillers you can prefill to your hearts content using this cap.
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
LIKE2BUILD
I have always pre-filled my oil filters. The angle needed to wiggle through the fender well prevents you from getting the filter full. However, you can fill it about 2/3 and not spill has you put it in place.
At bare minimum this amount of oil pre-wets the filter media and allows for quick flow when engine starts.
KJ
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
LIKE2BUILD
Ron3rd wrote:
I don't have a 4x4 and all I saw in the manual is to lube the front tie rod ends. Am I missing somethig?
I didn't catch that your truck is 2WD. Actually, all joints in the linkage are non-serviceable so you have nothing to grease.
KJ
1 forgiving wife!!!
