โMay-13-2016 08:51 AM
โMay-18-2016 03:42 PM
โMay-18-2016 03:17 PM
Bedlam wrote:
You need the tall skinny tires - The wider ones will float more (yes, even with all that weight) and not give you as much bite.
โMay-18-2016 02:51 PM
โMay-18-2016 02:14 PM
Bedlam wrote:
Thinner tires will do better in rain, snow or mud and fatter ones in sand. What type of traction do you need?
You can also mix tread widths and types as long as overall height is the same. You can go with a wider less aggressive front tire to keep down tread noise yet give you good flotation and use skinnier more aggressive rear tires to give you more bite. In this case, your spare should match what you choose for the rear.
โMay-18-2016 01:48 PM
โMay-18-2016 11:20 AM
mkasner wrote:
I keep hearing the new KO2 are not last long on heavier trucks... I am in the same boat as you, need new tires and am on the fence with either the KO2 or Duratracs
โMay-18-2016 11:16 AM
โMay-18-2016 11:10 AM
โMay-18-2016 09:58 AM
Vinsil wrote:
Very nice...I'll suggest a 285/70/19.5. I love mine!!!
โMay-17-2016 08:21 PM
2BLAZERS wrote:
So here is the latest.
With the SuperSprings on the rear and 2'' leveling kit on the front now. Installed this morning.
Looks great and will work great too. Now to figure out the tire size I'm jumping too ๐ LOL.
โMay-17-2016 12:50 PM
โMay-17-2016 08:02 AM
โMay-16-2016 08:08 AM
โMay-16-2016 07:33 AM
