2016 Titan XD Cummins- TFL
jerem0621
Here is the TFL Video
Interesting to note...
Peak TQ- 1800 rpm
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
138 REPLIES 138
Turtle_n_Peeps
Fish wrote:
Just out of curiosity what did you race that cummins with?
32 Chevy with a 572. I ran a 9.6 and he ran a 9.4 with his coolant acting as water injection. :W
My point with the head bolt deal was this: I have never seen a diesel with 4 head bolts last. Some others may know of one but I don't. They all had head sealing issues even bone stock. That's why Ford got away from the stupid 6.0/6.4 four bolt design when they went with their own engine design. "Ford" got it right this time "with this issue". No sealing issues with their 6.7 at all. In all fairness, same goes for the other two. Funny when they go to a more than 4 bolt design the sealing issues go away.
Will this engine be the one that breaks the rule? I don't know? Cummins has a dam good design team but even the best make mistakes and cut too many corners sometimes.
I'm also not a big fan of chains to drive things after seeing what happen to my 6.5 chain. It was junk, and I do mean JUNK at 130K. And this is a heavy OEM chain. Look what is happing to the Ecoboost timing chains. Again, more problems with stupid chains and this is with a super light duty engine let alone a big diesel engine with heavy valves and high valve spring pressure.
Can Cummins design around these issues? I sure hope, so but there is no way in hell I would be a test monkey on a 50 grand bet on the table. There is a lot of gamblers with a lot of money on this forum. I'm not one of them. ๐Ÿ™‚
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
FishOnOne
Turtle n Peeps wrote:
FishOnOne wrote:
jus2shy wrote:
Surprised that the final mass is 800 lbs. That's pretty darn good. Also surprised that on another video, they stated payload of the Titan XD to be north of 2,000 lbs. So that payload and 12k towing is perfect for those that want a smaller 5'er or travel trailer. I think Nissan has targeted the right group. I also love how simplistic the compound turbo setup is. The turbo assembly only has 4 moving parts counting the wastegate, M2 turbine nozzle, and the turbine/compressor wheel assemblies for both turbos. Far more elegant than International's attempt with the VG turbo and large fixed turbo. Hopefully it works out in the real world as well.
Surprised Cummins used only 4 head bolts per cylinder and all that chain on the front of that engine is crazy.
What's wrong with 4 head bolts per cylinder? Ford ok'ed the use of that design in all of the 6.0 engines that went in their trucks. GM also had only 4 bolts/ cylinder in their 5.7 diesel and it was.....
Oh.............hmmmmmmm..........I see your point now! :B
As far as the mile long chain goes; what's wrong with that? Again Ford used that design with their Ecoboost and they had............... oh...........hmmmmmmmm...........I again see your point. :B
FYI you can have 6 head bolts/cylinder and still have head gaskets blow... i.e. 6.7 cummins.
I totally agree.....................when you put 100 lbs of boost to it!!!! Pop goes the weasel!!!
Last weekend I raced this old Cummins with a bunch of real nice head studs holding the head down. Guess what happened? Yep, pop goes the weasel!!! Or in this case, the head gasket. :B I don't know how much boost he was running on my run but a few weeks ago it was 147 LBS!!!! :E
As far as the chain goes. My chain was JUNK on my 6.5 diesel at 130K. And this engine still had cross hatch marks in the bores and the lower end bearings looked like brand new. The heavy valve spring pressures and the HPFP load just eats these things up. Anybody know what the heavy duty option for the 6.5 diesel was to drive the cam? Yep, gear to gear.
There is a reason heavy duty diesels go with gear to gear and stay away from chains. Chains are for bicycles! :B
Don't confuse a 5.9 cummins vs a 6.7 cummins for head gasket failure. But I do agree the 5.9 can take a lot of abuse as long a the deck and head are perfectly flat with robust clamping.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Turtle_n_Peeps
outside the fire"
FishOnOne
jus2shy wrote:
Huh, did not catch that. Good eye. As for the head lift issue and popped gaskets, it was my understanding that occurred mostly on deleted and tuned vehicles. Haven't read of a head gasket failure on a 13 and up stock truck or many other stock 6.7 engines from previous years.
For chain drive, makes sense for overhead cam engines. Just about all overhead cam engines are chain driven, and given the lower operating rpm of a diesel, it will probably last a good long time before needing service. I do prefer gear drive though. I'll download an owners manual as soon as they come out and see if it is a service item just out of curiosity.
I'm more concerned what the oil dilution (especially when running bio diesel) will have on the long term reliability of the chains and the plastic tensioners.
jus2shy
E'Aho L'ua
2013 RAM 3500 Crew Cab 4x4 SRW |Cummins @ 370/800| 68RFE| 3.42 gears
Currently Rig-less (still shopping and biding my time)
FishOnOne
rjstractor
kw/00 wrote:
I wished that engine was available to other brands of trucks such as Toyota. The Nissan has never caught my eye and frankly its not a truck that I would buy. However it would be nice in a Tundra. Or if GM got going on the rumored 4.5 duramax for the 1/2 tons that would fit the bill for a lot of RV 1/2 ton owners. Regardless I can see a lot of sales for Nissan due to the engine alone, good move on there part.
Looks like you'll likely get your wish. Hopefully Toyota will too produce a truck with decent payload. Here's my source
2017 VW Golf Alltrack
2000 Ford F250 7.3
brulaz
Do the other V8 diesels not use chains?
Or maybe they are not overhead-cam?
EDIT: This. I see elsewhere they are push rod.
It just seems like chains are pretty common in V8 overhead cam engines.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
Turtle_n_Peeps
outside the fire"
jerem0621
I noticed the head bolt count as well... I hope that Cummins was able to dial in the clamping force needed to keep the head gaskets stable.
Time will tell...
As for the chains, it may be a non issue, I know that Ford has had good success with the huge and long timing chains on the OHC motors it has had for nearly 25 years.
Time will tell there too. M
Thanks!
Jeremiah
TT - Zinger 270BH
~Walt Disney~
brulaz
The chains bother me too. One for each cam shaft, one for the fuel pump and one for the oil pump I guess. My 2005 Passat TDI only had one for the oil pump and that quickly caused trouble. Luckily VW had a geared replacement for it.
Not sure if I buy the argument that chains are quieter than gears. But imagine the clockwork required to replace those 4 chains with gears.
FishOnOne
Targa
Nope....nope, just can't do it . Tried to keep an open mind but I just can't. The Cummins in a Nissan just isn't happening for me.
jus2shy
spud1957 wrote:
What fuel pump does it have?
CP 4.2. I'm betting the reason why all current consumer diesels are running this pump (save for the 6.7 Cummins) is because they need the higher injection pressures to achieve finer atomization to meet emissions specs.
However, the most likely reason why the Cummins 6.7 can get away with the CP3 is because they probably built up plenty of emissions credits by pretty much meeting 2010 emissions back in 2007 and are now making use of those credits to keep producing the current engines we have. The peak pressure for a cp3 is like 23,000 psi versus the CP4 achieving 28 or 29,000 psi. I also think the emissions of the CP3 fueled Cummins 6.7 isn't that far off from 2010 EPA mandates (or maybe it's actually dead on in meeting them), so they can spread that credit over a large number of engines (if they're indeed using credits).
With the ISV, Cummins never had the opportunity to build emissions credits, so they have to meet all emissions specs today.
E'Aho L'ua
spud1957
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
