โAug-23-2016 02:43 PM
โAug-26-2016 08:44 PM
FishOnOne wrote:Cummins12V98 wrote:1jeep wrote:
the only gain I saw with the 450 (on paper) would be the bigger rear axle and wheels, ratings were the same 14k gvwr. So for me that's all I cared about.
The 14K is just a number for licensing and insurance purposes. I weigh over 15K loaded and I am at or within axle ratings.
You can't run RAWR plus unloaded front axle without being over 14K.
The F450 also has larger brake calipers on the front end than a F350.
โAug-26-2016 07:11 PM
โAug-26-2016 08:45 AM
โAug-26-2016 08:41 AM
1jeep wrote:
4:30 gears were not part of the HD tow package, that was an additional $350 on the 2016 models and so far I have not regretted getting either option!
BTW....believe it or not I didn't opt for the 450 because I didn't want the 19.5" wheels, maybe I will regret that someday ...that day hasn't arrived yet.
โAug-25-2016 07:08 PM
โAug-25-2016 07:02 PM
โAug-25-2016 01:28 PM
โAug-25-2016 01:24 PM
That is incorrect. The DRW 350 got the 4.30 gears and wide track as part of the High Capacity tow package from 2011-2016. Either option could not be ordered as a stand alone option. You got them in the package or you didn't get them at all.
โAug-25-2016 12:32 PM
โAug-25-2016 12:24 PM
โAug-25-2016 12:18 PM
โAug-25-2016 12:12 PM
โAug-25-2016 12:07 PM
1jeep wrote:
Ok, I will believe you but I don't understand why they don't then state that 3:73 is deleted for that reason. I did once try to find where ford states exactly what makes the HD tow, not sure where they've hidden that info.
I see that KR 350 drw is still on the lot since January, im sure eventually someone will get a good deal on it.
โAug-25-2016 12:04 PM
