โJul-10-2019 07:48 PM
โJul-14-2019 09:36 PM
harmanrk wrote:4x4ord wrote:
I certainly don't have any interest in ordering and stocking spare parts that I will likely never use. I might change the primary filter once in the time I own a truck but it's unlikely I'll ever change the under hood filter.
When you buy the kit, it comes with both filters (You may be able to buy them individually, but I did not see that as an option when I ordered mine), so I don't know why you would not replace them together.
โJul-14-2019 08:20 PM
Lynnmor wrote:StirCrazy wrote:
the under hood filter is the same as on my 14, one of the eaisest fuel filters I have changed in a newer vehical. no special tools needed and very easy to get off. the only issue I have come up with is it hanging up in the bracket at times.
Steve
I believe that a 2014 has two fuel lines attached to the filter and the 2017 has three, with the added fuel line being the tiny fragile one.
โJul-14-2019 07:00 AM
harmanrk wrote:
That said, I have the replacement filter in front of me, and it certainly appears that all three lines are sturdy. Yes, one is half the diameter as the others, but the plastic is nearly the same thickness.
โJul-14-2019 06:16 AM
โJul-14-2019 05:15 AM
โJul-14-2019 02:36 AM
โJul-13-2019 06:27 PM
Steve
โJul-13-2019 05:39 PM
โJul-13-2019 04:39 PM
ShinerBock wrote:
Well, then don't get mad when people take your words as yelling or disrespectful. Just saying, you might get a little further with people if you didn't talk to them that way. You can do what you want, but they can do what they want in return as well. I will just continue to return disrespect with disrespect. Makes no difference to me.
โJul-13-2019 04:27 PM
Cummins12V98 wrote:
rhagfo, are you opposed to changing from the top and if so why? I assume you would like to give the turbo spin, check boost clamps and look for hose wear as I pictured.
โJul-13-2019 03:37 PM
โJul-13-2019 03:34 PM
โJul-13-2019 02:02 PM
Cummins12V98 wrote:
Sorry I was NOT yelling, your interpretation NOT mine. I clearly stated what I meant, guess that was not good enough.
Funny you just now make this comment as this is how "I" convey what I am trying to say. Been doing so ever since joining this and other forums I belong to, NEVER have I been accused of yelling.
โJul-13-2019 01:54 PM
Flashman wrote:
After having done it a couple of times - I find the CTD filter change using the fender cut out access very easy 15 minutes max. A filter cap is a must to keep from making a mess. Easier in opinion than the older CTDs and having to do it from the bottom.
โJul-13-2019 01:50 PM
ShinerBock wrote:Cummins12V98 wrote:
"WHY ARE YOU YELLING CERTAIN WORDS AT ME? "
Seriously??? I emphasize a couple words and I am YELLING???
Didn't think you were the sensitive type. :B
That is what capital letters mean when you type them, yelling. It is a bit rude to do hence the reason why respectable(and normal) people don't do it unless they are mad or purposely being disrespectful to someone. Maybe that is why so many people here are at odds with you.
