2019 Chevy LTZ Duramax CC Dually payload?
billtex
Hi All, time for a new ride.
Can anyone give me a good idea of scale weight of truck and/or available payload?
Thx, Bill
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
6 REPLIES 6
billtex
Thanks All.
First thing i do is check the door/glovebox...but that doesnโ€™t give you actual truck and axle weights. Only a trip to the scales will give you those numbers!
Hereโ€™s another (crazy) question; 2 similar trucks one lists the โ€œAโ€ dimension (camper loading) as 43โ€ the other as 62โ€!
WTF?
I thought GM always measured the โ€œAโ€ from the rear?!
2020 F350 CC LB
Eagle Cap 850
JIMNLIN
gm weights calculator
Use GM weight calculator. It figures std packages and all added options for the trucks axle weights and gvwr weights.
The only way to find a trucks real payload is scaled axle weights. Then do the math.
Example from the calculator; ....3500 DRW 2wd LTZ diesel crew cab long bed = 6476 RAWR payload...5816 gvwr payload.
jimh406
https://www.chevrolet.com/content/dam/chevrolet/na/us/english/index/vehicles/2019/trucks/silverado-h...
For 3500 DRW, it starts at these numbers. Actual numbers may vary due to how itโ€™s configured. Best thing to do is go read some door stickers for the models you want.
Gasoline 6112 lbs
Diesel 5281lbs
work2much
Did Chevy up their GVWR number to 14k? I thought is was less.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
azdryheat
My 2013 scaled at 8800. My payload is just under 5k.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Grit_dog
Navigator
Navigator
14k gvw, payload will be around 5500lbs. Guessing truck is about 8500.
