Aug-26-2014 05:08 PM
May-28-2019 09:20 AM
sonuvabug wrote:
Nov-07-2014 08:50 AM
Nov-07-2014 07:53 AM
Nov-07-2014 06:10 AM
805gregg wrote:/Users/Bill/Pictures/iPhoto Library/Modified/2010/Mar 4, 2010/IMG00042-20100304-1624.jpg
I got a Curt 2.5" 20,000 lb hitch from Hitchanything for less than $300, it attaches under my factory 2" hitch. Then got a 34" 2.5 Curt hitch extension again from Hitch anything, for $134. I used a piece of 2" square tubing to extend the 2" receiver and some 1/4" flat bar stock bolted to both to tie the 2 together. The 2.5" Curt extension is rated at 6000lbs at 34" so mine is even stronger that that, basically a better superhitch for under $450
Nov-07-2014 05:41 AM
Nov-06-2014 04:47 PM
Nov-06-2014 07:13 AM
Nov-06-2014 06:40 AM
Bedlam wrote:
... snipped ... I think that setup will work fine for the amount of hitch weight you are applying ... My hitch weight is 2-3x more than yours and I have not seen a better extension system than TorkLift's for those of us that pull heavy trailers.
Nov-06-2014 06:30 AM
Nov-06-2014 06:17 AM
Aug-31-2014 09:12 AM
Aug-31-2014 06:16 AM
dadwolf2 wrote:
The chains I am referring to are not the trailer safety chains. Like you said, that needs to go to the truck. The chains I mentioned are just to strengthen the extended hitch point in turns and any side to side play/movement.
I bought 2" stock / receiver and then cut & welded the parts to the size I needed from the local trailer hitch supply store.
Aug-30-2014 04:33 PM
Aug-30-2014 03:17 PM
mkirsch wrote:
The thing about extending the receiver is there are bolt-on solutions out there.
Not so when extending the trailer tongue. You need custom fabrication.
Reality Check has piqued my curiosity on the tongue extensions. Do you have any pictures you could share?
