3 way dometic fridge LP issue
cljward
On our last trip with our camper our fridge would not operate consistently on LP. It is a Dometic 3 way unit so it kept defaulting to the DC mode. Good thing we had a generator and 160 watts of solar as we were dry camping.
Any suggestions to what I should look at before I run the camper in for service. Both the heater and generator are also on that side of the camper and there were no supply issues to either of these.
At first I thought that it may have had to do with the elevation we were at, near 8,000 ft, but we also had the same issue when we got back to near sea level.
At night the unit would Switch off LP about every two hours. During the day it would run for longer intervals on LP but it would eventually switch over to D.C.
Thanks in Advance
10 REPLIES 10
Dave_Pete
Believe it or not a broken plastic selector switch can prevent full gas selection while other positions work. Check the knob. Just one possibility.
sbryan
Just another data point. When we were camping at around 8,000 feet in Denali I had the same issue with the fridge. I did clean debris out of the burner and it helped but until we got to lower altitudes the propane was problematic. Not clear to me why this would be an issue and there is no adjustment on the burner that I could find to adjust for altitude but I did have similar issues. Coincidence? Perhaps but I'd be curious if anyone else has had similar issues.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
GeoBoy
My 2 way refer would go out for no reason this season. I replaced the burner nozzle and all was well until the refer went out and when trying to relite it would make a popping sound. Traced that popping problem to a new cylinder not having the air properly purged.
HMS_Beagle
I've had two problems with a gas refer: one is the debris on the burner, either occluding the slots that make up the burner or partially bridging the igniter, making ignition intermittent. The other was low gas pressure caused by the regulator going off spec. That one has happened twice. Another was the electronics board going bad, +1 on the Dinosaur board. I guess that was three problems.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
cljward
Thanks for all the good advice. I will start with checking the burner.
I really appreciate this truck camper forum as I have picked up some great tips and advice by monitoring it from time to time.
cljward
I really appreciate this truck camper forum as I have picked up some get tips and advice by monitoring it from time to time.
Tiger4x4RV
Do you hear it try to spark? If no, check the igniter. And everything everyone else suggested.
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
deserteagle56
rrupert wrote:
Check the voltage coming to the fridge and also the gas pressure. I had a gas regulator problem and it affected the operation. If you can access the burner look for spider webs, mud dauber deposits and carbon buildup. LP seems to attract the little critters.
This. I was having a similar problem with my Bigfoot. Cleaning the burner assembly cured it - couldn't believe the buildup of debris in there.
1996 Bigfoot 2500 9.5 on a 2004 Dodge/Cummins dually
rrupert
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
donn0128
Control board, blown fuses. Before you spend $$$ for someone else to look at it, contact Dinosaur boards and ask then. There good about helping you diagnose things. Plus their boards are better than factory ones.
