Aug-16-2014 06:28 AM
Aug-19-2014 05:57 AM
aepowell wrote:
Does the meter need to be wired to where the power comes into the trailer?
Aug-19-2014 05:27 AM
Aug-19-2014 12:05 AM
Aug-16-2014 10:36 AM
Big Katuna wrote:Bumpyroad wrote:
I made an adapter with a 50 amp male plug and two 30 amp female pigtails. I could choose the side that had the best current.
bumpy
All Amps are created equal. And if one leg has higher voltage then the other, there is something really wrong.
I added a recep on the bed pedestal wired to a 30' extension cord.
My AC comes into the RV under the bed so it was easy to run the new cord into the power bay. When on 30A I plug it into the extra recep on the CGs pedestal so DW has a place to plug in her hair dryer or the electric water boiler.
Aug-16-2014 10:16 AM
bumpy
Aug-16-2014 10:07 AM
Golden_HVAC wrote:
Don't worry about it so much. Only worry about it dropping below 108 volts while running the A/C then keep an eye on it.
Fred.
Aug-16-2014 10:01 AM
bumpy
Aug-16-2014 09:45 AM
Aug-16-2014 09:24 AM
tbolt2000 wrote:
At a campsite and the AC Voltage on my AC line meter I'd reading 116 to 115 voltage. It has jumped from 113 to 116 with AC running. Last night when it was down to 113 we ran the microwave and it dropped down to 111.
The question is if getting a 50 amp to 30 adapter and move to the 50 amp might have better results with the AC Line meter reading?
Aug-16-2014 09:20 AM
Aug-16-2014 09:10 AM
Porsche or Country Coach!
Aug-16-2014 09:02 AM
RoyB wrote:
I do this all time when connecting up my 30AMP trailer. If I see alot of ware and tare on the 30AMP Service I will use my 50A-30A adapter and use that side.
However just a couple of VOLTS DROP is not a whole of VOLTAGE DROP when you kick in something high wattage like the Microwave.
What you don't want to see is the AC Voltage going below the 110VAC level... Some users will accept 105VAC as minimum level to use... I have seen the 30A service in the low 90s at times.
Most campers are the smaller size and only use 30AMP Service so you can imagine what happens to campground grid when most of the users are 30AMP service.
I use one of the RV 120VAC PLUG-IN meter in both my 30A trailers. This is neat because it has the SAFE ZONE painted in GREEN on the scale.
Roy Ken
Aug-16-2014 08:49 AM
Aug-16-2014 06:48 AM
Mandalay Parr wrote:
It may or may not. You can try it. Normally 50 amp connections are not as worn as 30.
You may also have some line loss within your rig.
