โAug-25-2016 09:36 AM
โAug-26-2016 09:15 AM
โAug-26-2016 06:24 AM
โAug-26-2016 04:31 AM
โAug-25-2016 09:34 PM
SoCalDesertRider wrote:
... because you were too stupid to break it in the way they tell you...
โAug-25-2016 07:42 PM
taken wrote:Lessmore wrote:taken wrote:
All the replies will be anecdotal. One person saying they always do what the manual says and has no issue proves nothing. Just like one person posting they never do what the manual says and never have issues. It's all opinion.
Following what the manufacturer's manual says...is not opinion...it's direct instruction from the company engineers who developed and tested the machine.
The OP was asking for an OPINION on whether to follow the recommendation or not. No one is questioning if the recommendation is there or not. LOL. Try again...
โAug-25-2016 07:38 PM
โAug-25-2016 06:55 PM
โAug-25-2016 06:47 PM
TBammer wrote:That is a very good plan indeed. You are wise, grasshopper. ๐
I did some research and learned a lot about gearsets in the differential, and how they harden during the break in period through repeated heating and cooling, which causes metallurgical changes to the castings. The concern is that early on they heat up from the friction as the gears mesh and surfaces harden. If the oil overheats the process is corrupted and can compromise the strength of the parts. The speed shops all recommend changing the rear end oil after the break in. As someone who wants a truck to last, I will be following the experts recommendation. I was just a little taken aback by the information. Learn something new everyday.
So the plan is to take it out last twice a day for 15-20 mile drives of varying speed, without prolonged high speeds. Just means taking a long way around to work and home, which should do the trick until the mileage is hit,
โAug-25-2016 04:41 PM
โAug-25-2016 03:54 PM
DownTheAvenue wrote:That covers it. Excellent! ๐taken wrote:
The break in period is for the gearset and not the engine. I would head the 500 miles without towing recommendation. I would ignore the under 50MPH though once you begin towing...
I would follow the owner's manual. The engineers who designed and built your truck know what is best, not someone with a keyboard and an internet connection.
โAug-25-2016 03:18 PM
โAug-25-2016 02:45 PM
โAug-25-2016 02:26 PM
โAug-25-2016 02:04 PM
โAug-25-2016 01:50 PM
